[SCM] PostGIS branch master updated. 3.6.0rc2-677-g370c6a160
git at osgeo.org
git at osgeo.org
Tue Jun 30 12:05:18 PDT 2026
the project "PostGIS".
via 370c6a160a21d46b0768fb70ea0d75292cc475d0 (commit)
from 1b98624e5a6d7eda27dfbc15c52b3af53043dcd3 (commit)
revisions in full, below.
commit 370c6a160a21d46b0768fb70ea0d75292cc475d0
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date: Tue Jun 30 12:05:14 2026 -0700
Use GEOSSplit where available for ST_Split
diff --git a/liblwgeom/lwgeom_geos_split.c b/liblwgeom/lwgeom_geos_split.c
index 15ca6ff5c..883a17751 100644
--- a/liblwgeom/lwgeom_geos_split.c
+++ b/liblwgeom/lwgeom_geos_split.c
@@ -112,12 +112,23 @@ lwline_split_by_line(const LWLINE* lwline_in, const LWGEOM* blade_in)
- gdiff = GEOSDifference(g1,g2);
+#if POSTGIS_GEOS_VERSION >= 31500
+ /* GEOS 3.15 added an explicit splitter. Older GEOS relies on the
+ * side-effect of GEOSDifference returning the input split at the
+ * crossing points of the (non-overlapping) blade. */
+ gdiff = GEOSSplit(g1, g2);
+#else
+ gdiff = GEOSDifference(g1, g2);
+#endif
GEOSGeom_destroy(g1);
GEOSGeom_destroy(g2);
if (gdiff == NULL)
+ lwerror("GEOSSplit: %s", lwgeom_geos_errmsg);
+#else
lwerror("GEOSDifference: %s", lwgeom_geos_errmsg);
+#endif
return NULL;
@@ -353,6 +364,69 @@ lwline_split(const LWLINE* lwline_in, const LWGEOM* blade_in)
static LWGEOM*
lwpoly_split_by_line(const LWPOLY* lwpoly_in, const LWGEOM* blade_in)
+ /* GEOS 3.15 splits polygons directly, filtering out the pieces that
+ * fall inside holes for us. On older GEOS we reproduce that logic by
+ * polygonizing the boundary unioned with the blade and discarding the
+ * pieces whose point-on-surface is not contained by the input (#else). */
+ LWGEOM* split;
+ LWCOLLECTION* out;
+ GEOSGeometry* g1;
+ GEOSGeometry* g2;
+ GEOSGeometry* gsplit;
+ int hasZ = FLAGS_GET_Z(lwpoly_in->flags);
+ initGEOS(lwgeom_geos_error, lwgeom_geos_error);
+ g1 = LWGEOM2GEOS((LWGEOM*)lwpoly_in, 0);
+ if ( NULL == g1 )
+ lwerror("LWGEOM2GEOS: %s", lwgeom_geos_errmsg);
+ return NULL;
+ g2 = LWGEOM2GEOS(blade_in, 0);
+ if ( NULL == g2 )
+ GEOSGeom_destroy(g1);
+ return NULL;
+ gsplit = GEOSSplit(g1, g2);
+ GEOSGeom_destroy(g2);
+ if ( NULL == gsplit )
+ return NULL;
+ split = GEOS2LWGEOM(gsplit, hasZ);
+ GEOSGeom_destroy(gsplit);
+ if ( NULL == split )
+ lwerror("GEOS2LWGEOM: %s", lwgeom_geos_errmsg);
+ return NULL;
+ /* GEOSSplit always returns a collection, but wrap defensively */
+ out = lwgeom_as_lwcollection(split);
+ if ( ! out )
+ LWGEOM** components = lwalloc(sizeof(LWGEOM*));
+ components[0] = split;
+ out = lwcollection_construct(COLLECTIONTYPE, lwpoly_in->srid,
+ NULL, 1, components);
+ else
+ lwgeom_set_srid((LWGEOM*)out, lwpoly_in->srid);
+ out->type = COLLECTIONTYPE;
+ return (LWGEOM*)out;
+#else
LWCOLLECTION* out;
GEOSGeometry* g1;
GEOSGeometry* g2;
@@ -491,6 +565,7 @@ lwpoly_split_by_line(const LWPOLY* lwpoly_in, const LWGEOM* blade_in)
GEOSGeom_destroy(polygons);
+#endif /* POSTGIS_GEOS_VERSION >= 31500 */
static LWGEOM*
Summary of changes:
liblwgeom/lwgeom_geos_split.c | 77 ++++++++++++++++++++++++++++++++++++++++++-
1 file changed, 76 insertions(+), 1 deletion(-)
hooks/post-receive
