[PostGIS] #6044: winnie failing make check because of docbook xml validate errors
PostGIS trac at osgeo.org
Tue Jun 30 13:07:39 PDT 2026
  Reporter:  robe     |      Owner:  robe
      Type:  defect   |     Status:  closed
  Priority:  blocker  |  Milestone:  PostGIS 3.3.9
 Component:  install  |    Version:  3.3.x
Resolution:  fixed    |   Keywords:
Changes (by Darafei Praliaskouski <me@…>):
 * resolution:   => fixed
 * status:  assigned => closed
Comment:
 In [changeset:"7554ee86fc7a1429bfcac26d3173ffd7c04caf4b/git" 7554ee8/git]:
 {{{#!CommitTicketReference repository="git"
 revision="7554ee86fc7a1429bfcac26d3173ffd7c04caf4b"
 Skip XML checks without DocBook XSL on stable-3.2
 Backport the 3.4 Winnie/doc check guard so check-unit does not run check-
 xml when XSLBASE is unset.
 Closes #6044 for PostGIS 3.2.11
 Ported-from:
 https://gitea.osgeo.org/postgis/postgis/commit/30b1d54dac01f0f4cb92ba6ba47ecd5bb5ce3e69
Ticket URL: <https://trac.osgeo.org/postgis/ticket/6044#comment:3>
