[SCM] PostGIS branch master updated. 3.6.0rc2-698-gb6204431f
git at osgeo.org
git at osgeo.org
Tue Jun 30 22:35:26 PDT 2026
the project "PostGIS".
via b6204431fcfdb386ca58fe495fa23bdbd5461b5b (commit)
via a2a5bb897a499aaac56f30af583bb8f9febe2865 (commit)
from 058ffbeab6ee29678b331724488cfd4c7e5d7e84 (commit)
revisions in full, below.
commit b6204431fcfdb386ca58fe495fa23bdbd5461b5b
Merge: 058ffbeab a2a5bb897
Author: Darafei Praliaskouski <me at komzpa.net>
Date: Wed Jul 1 09:33:27 2026 +0400
Merge pull request https://github.com/postgis/postgis/pull/936
doc: document ST_Translate M preservation
commit a2a5bb897a499aaac56f30af583bb8f9febe2865
Date: Wed Jun 17 10:31:53 2026 +0400
References #3063
diff --git a/doc/reference_transformation.xml b/doc/reference_transformation.xml
index ec35f9497..f631bea23 100644
--- a/doc/reference_transformation.xml
+++ b/doc/reference_transformation.xml
@@ -520,13 +520,15 @@ SELECT ST_AsText(ST_Scale('LINESTRING(1 1, 2 2)', 'POINT(2 2)', 'POINT(1 1)'::ge
<title>Description</title>
<para>Returns a new geometry whose coordinates are translated delta x,delta y,delta z units. Units are
- based on the units defined in spatial reference (SRID) for this geometry.</para>
+ based on the units defined in spatial reference (SRID) for this geometry.
+ M coordinates are preserved.</para>
<note><para>Prior to 1.3.4, this function crashes if used with geometries that contain CURVES. This is fixed in 1.3.4+</para></note>
<para role="availability" conformance="1.2.2">Availability: 1.2.2</para>
<para>&Z_support;</para>
<para>&curve_support;</para>
+ <para>&M_support;</para>
</refsection>
<refsection>
@@ -550,6 +552,17 @@ SELECT ST_AsText(ST_Scale('LINESTRING(1 1, 2 2)', 'POINT(2 2)', 'POINT(1 1)'::ge
st_asewkt
POINT(5 12 3)
+ </programlisting>
+ <para>Move points with a measure coordinate</para>
+ <programlisting>SELECT ST_AsEWKT(ST_Translate(ST_GeomFromEWKT('POINTM(0 0 11)'), 5, 12));
+ st_asewkt
+ POINTM(5 12 11)
+SELECT ST_AsEWKT(ST_Translate(ST_GeomFromEWKT('POINT(0 0 7 11)'), 5, 12, 3));
+ st_asewkt
+ POINT(5 12 10 11)
</programlisting>
<para>Move a curve and a point</para>
<programlisting>SELECT ST_AsText(ST_Translate(ST_Collect('CURVEPOLYGON(CIRCULARSTRING(4 3,3.12 0.878,1 0,-1.121 5.1213,6 7, 8 9,4 3))','POINT(1 3)'),1,2));
diff --git a/regress/core/affine.sql b/regress/core/affine.sql
index 8b7f43e86..1c5bdedfb 100644
--- a/regress/core/affine.sql
+++ b/regress/core/affine.sql
@@ -3,6 +3,8 @@
-- ST_Translate
select 'ST_Translate', ST_asewkt(ST_Translate('POINT(0 0)'::geometry, 5, 12));
select 'ST_Translate', ST_asewkt(ST_Translate('POINT(0 0 0)'::geometry, -3, -7, 3));
+select 'ST_TranslateM', ST_asewkt(ST_Translate(ST_GeomFromEWKT('POINTM(0 0 11)'), 5, 12));
+select 'ST_TranslateZM', ST_asewkt(ST_Translate(ST_GeomFromEWKT('POINT(0 0 7 11)'), 5, 12, 3));
-- ST_Scale
select 'ST_Scale', ST_asewkt(ST_Scale('POINT(1 1)'::geometry, 5, 5));
diff --git a/regress/core/affine_expected b/regress/core/affine_expected
index ba6723a0d..ebee7b0de 100644
--- a/regress/core/affine_expected
+++ b/regress/core/affine_expected
@@ -1,5 +1,7 @@
ST_Translate|POINT(5 12)
ST_Translate|POINT(-3 -7 3)
+ST_TranslateM|POINTM(5 12 11)
+ST_TranslateZM|POINT(5 12 10 11)
ST_Scale|POINT(5 5)
ST_Scale|POINT(3 2)
ST_Scale|POINT(40 40 40)
Summary of changes:
doc/reference_transformation.xml | 15 ++++++++++++++-
regress/core/affine.sql | 2 ++
regress/core/affine_expected | 2 ++
3 files changed, 18 insertions(+), 1 deletion(-)
hooks/post-receive
