[PostGIS] #6089: wrong node used when adding a new long line
trac at osgeo.org
Tue Jun 30 22:45:44 PDT 2026
Reporter: Lars Aksel Opsahl | Owner: strk
Type: defect | Status: new
Priority: medium | Milestone:
Component: topology | Version: master
Resolution: | Keywords: snap
Changes (by strk):
* keywords: => snap
Comment:
I could reproduce with just using ST_Snap. This is a simplified testcase:
CREATE SCHEMA t6089;
CREATE TABLE t6089.edge ( id int primary key, geom geometry );
INSERT INTO t6089.edge VALUES
( 5,
'0102000020A210000002000000154AE61BA01A2840A2F897DE1D715040E822874E991A284032362A1D1D715040'
( 4,
'0102000020A21000000200000014F1AC1FA01A28406C5803DF1D715040154AE61BA01A2840A2F897DE1D715040'
-- Offending input
CREATE TABLE t6089.incoming AS SELECT
1::int as id,
'0102000020A210000002000000C01856A5171528406C5803DF1D71504064BFAEFB153728406C5803DF1D715040'::geometry
g;
-- Input snapped to edges
create table t6089.incoming_snapped as select i.id, ST_Snap(i.g,
st_collect(e.geom), 1e-07) from t6089.incoming i, t6089.edge e group by
i.id, i.g;
And this is what happens:
[[Image(snapping.png)]]
The lenght of the upper edge (completely covered by the snapped incoming
line) is computed by PostGIS to be ~1.5e-07 (so bigger than tolerance):
strk=# select id, ST_length(geom) from t6089.edge;
id | st_length
5 | 6.942671476753422e-05
4 | 1.5054470047841826e-07
(2 rows)
Ticket URL: <https://trac.osgeo.org/postgis/ticket/6089#comment:5>
