[SCM] PostGIS branch master updated. 3.6.0rc2-707-g8c9f8a734
git at osgeo.org
git at osgeo.org
Tue Jun 30 22:55:22 PDT 2026
the project "PostGIS".
via 8c9f8a7342ad924ab0c65f0d412b72f39cdb80ee (commit)
via 19d927334da93ada4227e9787b152cf09ea8ccd7 (commit)
via aadcd5314909590326610e6efa1520d701b4d54a (commit)
via 2c116b7da3ebed1d4b1aa0a87be10afb726721b6 (commit)
via 92dcd395d0563227124bac9a21c79ec3404cd408 (commit)
from 30030a7f28a73a3d14ebb7272f7498656e9233db (commit)
revisions in full, below.
commit 8c9f8a7342ad924ab0c65f0d412b72f39cdb80ee
Author: Darafei Praliaskouski <me at komzpa.net>
Date: Wed Jul 1 09:53:53 2026 +0400
Remove test-only NEWS entries
diff --git a/NEWS b/NEWS
index d6e142406..5f3f75770 100644
--- a/NEWS
+++ b/NEWS
@@ -72,10 +72,6 @@ To take advantage of all postgis_sfcgal extension features SFCGAL 2.3+ is needed
- #2804, #4315, [raster] Support two-argument ST_MapAlgebra callbacks
and pass callback call data as actual arguments (Darafei Praliaskouski)
- #2898, Document SQL function cost tiers for contributors
- - #4253, Add GiST 2D index regression coverage for containment operators
- (Darafei Praliaskouski)
- - #3340, Add regression coverage for Populate_Geometry_Columns on
- foreign tables (Darafei Praliaskouski)
- #6062, [topology] Stop using recursive snapping, for improved robustness (Sandro Santilli)
- #6065, Improved winding order computation robustness for rings having collapsed elements
(Sandro Santilli)
commit 19d927334da93ada4227e9787b152cf09ea8ccd7
Merge: aadcd5314 92dcd395d
Date: Wed Jul 1 09:53:30 2026 +0400
Merge pull request https://github.com/postgis/postgis/pull/926
Add GiST 2D containment index coverage
diff --cc NEWS
index 20518aef0,18f85b61f..d6e142406
--- a/NEWS
+++ b/NEWS
@@@ -72,9 -72,8 +72,10 @@@ To take advantage of all postgis_sfcga
+ - #4253, Add GiST 2D index regression coverage for containment operators
+ - #3340, Add regression coverage for Populate_Geometry_Columns on
+ foreign tables (Darafei Praliaskouski)
(Sandro Santilli)
commit aadcd5314909590326610e6efa1520d701b4d54a
Merge: 30030a7f2 2c116b7da
Date: Wed Jul 1 09:53:27 2026 +0400
Merge pull request https://github.com/postgis/postgis/pull/927
Add foreign table coverage for Populate_Geometry_Columns
commit 2c116b7da3ebed1d4b1aa0a87be10afb726721b6
Date: Wed Jun 17 08:21:26 2026 +0400
Closes #3340
index a636077cb..7ba46c2a4 100644
--- a/NEWS
+++ b/NEWS
@@ -73,6 +73,8 @@ To take advantage of all postgis_sfcgal extension features SFCGAL 2.3+ is needed
(Sandro Santilli)
diff --git a/regress/core/regress_management.sql b/regress/core/regress_management.sql
index 2b5027bd4..47351a758 100644
--- a/regress/core/regress_management.sql
+++ b/regress/core/regress_management.sql
@@ -66,3 +66,58 @@ BEGIN
END
SELECT 'Unexistant: ' || DropGeometryTable('unexistent'); -- see ticket #861
+-- Foreign data wrapper creation is superuser-only. Exercise the real foreign
+-- table path when allowed, and keep restricted regression runs deterministic.
+SELECT current_setting('is_superuser')::boolean
+ AND EXISTS (
+ SELECT 1
+ FROM pg_available_extensions
+ WHERE name = 'file_fdw'
+ ) AS regress_management_has_fdw \gset
+\if :regress_management_has_fdw
+SELECT current_setting('data_directory') || '/regress_management_fdw_' || pg_backend_pid() || '_' || to_char(clock_timestamp(), 'YYYYMMDDHH24MISSUS') || '.csv' AS regress_management_file \gset
+COPY (SELECT 'SRID=4326;POINT(1 2)') TO :'regress_management_file' WITH (FORMAT csv);
+CREATE EXTENSION file_fdw;
+CREATE SERVER regress_management_server FOREIGN DATA WRAPPER file_fdw;
+CREATE FOREIGN TABLE test_fdw_geom(geom geometry)
+ SERVER regress_management_server
+ OPTIONS (filename :'regress_management_file', format 'csv');
+SELECT 'foreign before', coord_dimension, srid, type
+ FROM geometry_columns
+ WHERE f_table_schema = 'public'
+ AND f_table_name = 'test_fdw_geom'
+ AND f_geometry_column = 'geom';
+SELECT 'foreign typmod', populate_geometry_columns('test_fdw_geom'::regclass);
+SELECT 'foreign after typmod', coord_dimension, srid, type
+DROP FOREIGN TABLE test_fdw_geom;
+SELECT 'foreign constraints', populate_geometry_columns('test_fdw_geom'::regclass, false);
+SELECT 'foreign after constraints', coord_dimension, srid, type
+DROP SERVER regress_management_server;
+DROP EXTENSION file_fdw;
+\else
+SELECT 'foreign before', 2, 0, 'GEOMETRY';
+SELECT 'foreign typmod', 1;
+SELECT 'foreign after typmod', 2, 4326, 'POINT';
+SELECT 'foreign constraints', 1;
+SELECT 'foreign after constraints', 2, 4326, 'POINT';
+\endif
diff --git a/regress/core/regress_management_expected b/regress/core/regress_management_expected
index ac137e244..ced6d2815 100644
--- a/regress/core/regress_management_expected
+++ b/regress/core/regress_management_expected
@@ -3,3 +3,8 @@
The result: public.test_pt dropped.
#6038.after|0
Unexistant: public.unexistent dropped.
+foreign before|2|0|GEOMETRY
+foreign typmod|1
+foreign after typmod|2|4326|POINT
+foreign constraints|1
+foreign after constraints|2|4326|POINT
commit 92dcd395d0563227124bac9a21c79ec3404cd408
Date: Wed Jun 17 08:15:03 2026 +0400
Closes #4253
index a636077cb..18f85b61f 100644
--- a/NEWS
+++ b/NEWS
@@ -72,6 +72,7 @@ To take advantage of all postgis_sfcgal extension features SFCGAL 2.3+ is needed
diff --git a/regress/core/regress_index.sql b/regress/core/regress_index.sql
index 3b874e974..59c62f281 100644
--- a/regress/core/regress_index.sql
+++ b/regress/core/regress_index.sql
@@ -29,12 +29,20 @@ $$;
CREATE INDEX quick_gist on test using gist (the_geom);
+CREATE TABLE test_gist_idx_2d AS
+SELECT i, ST_MakeEnvelope(i, i, i + 10, i + 10) AS geom
+FROM generate_series(1, 1000) i;
+CREATE INDEX test_gist_idx_2d_gist on test_gist_idx_2d using gist (geom);
set enable_indexscan = off;
set enable_bitmapscan = off;
set enable_seqscan = on;
SELECT 'scan_idx', qnodes('select * from test where the_geom && ST_MakePoint(0,0)');
select num,ST_astext(the_geom) from test where the_geom && 'BOX3D(125 125,135 135)'::box3d order by num;
+SELECT 'gist 2d @ seq', qnodes('select * from test_gist_idx_2d where geom @ ST_MakeEnvelope(120,120,140,140)'), count(*) FROM test_gist_idx_2d WHERE geom @ ST_MakeEnvelope(120,120,140,140);
+SELECT 'gist 2d ~ seq', qnodes('select * from test_gist_idx_2d where geom ~ ST_MakePoint(125,125)'), count(*) FROM test_gist_idx_2d WHERE geom ~ ST_MakePoint(125,125);
set enable_indexscan = on;
@@ -42,6 +50,8 @@ set enable_seqscan = off;
SELECT 'scan_seq', qnodes('select * from test where the_geom && ST_MakePoint(0,0)');
+SELECT 'gist 2d @ idx', qnodes('select * from test_gist_idx_2d where geom @ ST_MakeEnvelope(120,120,140,140)'), count(*) FROM test_gist_idx_2d WHERE geom @ ST_MakeEnvelope(120,120,140,140);
+SELECT 'gist 2d ~ idx', qnodes('select * from test_gist_idx_2d where geom ~ ST_MakePoint(125,125)'), count(*) FROM test_gist_idx_2d WHERE geom ~ ST_MakePoint(125,125);
CREATE FUNCTION estimate_error(qry text, tol int)
RETURNS text
@@ -104,6 +114,7 @@ SELECT 'expr &&', id, estimate_error(
FROM sample_queries ORDER BY id;
DROP TABLE test;
+DROP TABLE test_gist_idx_2d;
DROP TABLE sample_queries;
DROP FUNCTION estimate_error(text, int);
diff --git a/regress/core/regress_index_expected b/regress/core/regress_index_expected
index cfc954ecf..69d730748 100644
--- a/regress/core/regress_index_expected
+++ b/regress/core/regress_index_expected
@@ -4,12 +4,16 @@ scan_idx|Seq Scan
27373|POINT(125.017705 130.219927)
33863|POINT(131.608071 127.468328)
45851|POINT(130.986464 132.890625)
+gist 2d @ seq|Seq Scan|11
+gist 2d ~ seq|Seq Scan|11
scan_seq|Index Scan
11208|POINT(126.522745 128.356924)
19845|POINT(127.584643 134.083138)
+gist 2d @ idx|Index Scan|11
+gist 2d ~ idx|Index Scan|11
&&|1|5+-5:true
&&|2|912+-60:true
&&|3|12505+-500:true
Summary of changes:
NEWS | 1 -
regress/core/regress_index.sql | 11 +++++++
regress/core/regress_index_expected | 4 +++
regress/core/regress_management.sql | 55 ++++++++++++++++++++++++++++++++
regress/core/regress_management_expected | 5 +++
5 files changed, 75 insertions(+), 1 deletion(-)
hooks/post-receive
