[PostGIS] #6155: Slow getClosestEdge
trac at osgeo.org
Wed Nov 4 08:04:16 PST 2026
Reporter: Lars Aksel Opsahl | Owner: strk
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 3.7.1
Component: topology | Version: 3.6.x
Resolution: | Keywords:
Comment (by strk):
The patch is fine, we don't need the edge_id sort if not for
predictability of results in case of equidistant edges (mostly for
testcases).
When I try locally (PostgreSQL 17.11) I don't get a Gather Merge but this:
Limit (cost=1.29..2.46 rows=1 width=12)
-> Incremental Sort (cost=1.29..4869.27 rows=4150 width=12)
Sort Key: ((edge_data.geom <->
'0101000020A210000078966658E5CB2740A74EB847558A4F40'::geometry)),
edge_data.edge_id
Presorted Key: ((edge_data.geom <->
-> Index Scan using edge_gist on edge_data (cost=0.15..4682.52
rows=4150 width=12)
Order By: (geom <->
Why that Gather Merge expects over 750k rows while only getting 1 instead
I dunno. Did you run analyze before that query ? What version of
PostgreSQL are you running this on ?
Ticket URL: <https://trac.osgeo.org/postgis/ticket/6155#comment:3>
