[SCM] PostGIS branch master updated. 3.7.0rc3-11-gc87677a62
Tue Nov 10 01:26:34 PST 2026
the project "PostGIS".
       via  c87677a620f814978f9eb3dced943c2b1241d149 (commit)
       via  75d0d3d44cf85d8b02a40f5d326e173a47a1547b (commit)
      from  e55a99babec9ebca6048974840cc5fce979ef14c (commit)
revisions in full, below.
commit c87677a620f814978f9eb3dced943c2b1241d149
Author: Regina Obe <lr at pcorp.us>
Date:   Tue Nov 10 04:18:21 2026 -0500
    No longer supporting 32-bit debian since debian dropped support for 32-bit
     - Remove berrie (which was our 32-bit tester from ci matrix)
     - Remove from ci-images-runners.md
     - Change test_ci_status.py template to not use hard-code berrie
       instead prefer generic term syntethic worker for the template name
diff --git a/doc/development/testing/ci-images-runners.md b/doc/development/testing/ci-images-runners.md
index 1dc0a577f..faaa6ed31 100644
--- a/doc/development/testing/ci-images-runners.md
+++ b/doc/development/testing/ci-images-runners.md
@@ -39,7 +39,7 @@ without identifying a source defect.
 | Woodie agents | <https://gitea.osgeo.org/sac/woodpecker-agent-config>, branch `woodie-3` | OSGeo Woodpecker agent startup scripts and deployment notes |
 | Jenkins buildbot hosts | <https://gitea.osgeo.org/postgis/postgis-buildbots> | Linux, Debian, FreeBSD, Raspberry Pi, and Windows worker setup notes |
-| In-tree Jenkins scripts | `ci/debbie/`, `ci/winnie/`, `ci/bessie/`, `ci/berrie*` | Commands run by PostGIS Jenkins jobs and worker labels |
+| In-tree Jenkins scripts | `ci/debbie/`, `ci/winnie/`, `ci/bessie/`, `ci/berrie64/` | Commands run by PostGIS Jenkins jobs and worker labels |
 Woodpecker pull-request jobs run on Woodie agents. Agent capacity, Docker
 socket access, `binfmt_misc` handlers, DNS, and registry access are runner
@@ -51,8 +51,7 @@ Jenkins worker setup lives outside this repository in
 `postgis/postgis-buildbots`. That repository still contains historical setup
 notes as well as active worker notes, so use the maintained inventory in
 `utils/docs/ci_status/config.json` and the live Jenkins job labels before
-reviving an old platform. Current 32-bit coverage is the Berrie Raspberry Pi
-worker, which is 32-bit ARM. The old `bessie32` FreeBSD worker is not part of
+reviving an old platform. The old `bessie32` FreeBSD worker is not part of
 the maintained CI inventory; do not rebuild 32-bit FreeBSD coverage from the old badge table
 without fresh maintainer approval and a live worker readback.
@@ -65,8 +64,7 @@ Use the owning workflow or worker label for architecture claims:
   cover the branches where those files exist.
 * Woodpecker jobs currently declare `platform: linux/amd64` unless the
   workflow says otherwise.
-* Jenkins `berrie` is the maintained 32-bit ARM surface, and `berrie64` is the
-  Raspberry Pi 64-bit surface.
+* Jenkins `berrie64` is the Raspberry Pi 64-bit surface.
 * Jenkins `bessie` is the maintained FreeBSD surface; `bessie32` is retired
   from the maintained inventory.
diff --git a/doc/development/testing/ci.md b/doc/development/testing/ci.md
index 95e6ac98b..5f6142987 100644
--- a/doc/development/testing/ci.md
+++ b/doc/development/testing/ci.md
@@ -29,7 +29,7 @@ service that owns the behavior:
 | Woodpecker pull-request and branch pipelines | `.woodpecker/*.yml`, with pipeline status published by Woodie at <https://woodie.osgeo.org/repos/30> |
 | Debbie build, docs, and release jobs | `ci/debbie/`, the Debbie Jenkins jobs, and release-process notes |
 | Winnie Windows jobs | `ci/winnie/` and the Winnie Jenkins jobs |
-| Bessie and Berrie/Berrie64 jobs | `ci/bessie/`, `ci/berrie*`, and the corresponding Jenkins worker labels |
+| Bessie and Berrie64 jobs | `ci/bessie/`, `ci/berrie64/`, and the corresponding Jenkins worker labels |
 | Docker build images used by GitHub Actions | `postgis/postgis-build-env` image tags referenced from `.github/workflows/ci.yml` |
 | Docker build images used by Woodpecker | `repo.osgeo.org/postgis/build-test:*` image tags referenced from `.woodpecker/*.yml` |
 | Woodpecker MinGW Wine job | `.woodpecker/mingw-wine.yml` and `ci/woodie/postgis_mingw_wine.sh` |
@@ -95,7 +95,7 @@ only overlap part of its defect class.
 | Debbie Linux regression classes | Jenkins Debbie and Woodpecker | Mostly covered by Woodpecker's Linux regression and expensive QA workflows. Debbie still remains useful for its exact Jenkins host, dependency, and release-job environment. |
 | Make Dist | Jenkins Debbie | In flight in <https://gitea.osgeo.org/postgis/postgis/pulls/534>. Until that lands, Woodpecker does not check source distribution tarballs. |
 | FreeBSD and Bessie | GitHub Actions FreeBSD and Jenkins Bessie | In flight in <https://gitea.osgeo.org/postgis/postgis/pulls/549>. YAML running on a Linux container is not FreeBSD parity; this needs a FreeBSD VM or agent surface. |
-| 32-bit ARM and extra portability tiers | Jenkins Berrie | Covered by `.woodpecker/portability.yml` from <https://gitea.osgeo.org/postgis/postgis/pulls/516>, with hostile type-default coverage proposed in <https://gitea.osgeo.org/postgis/postgis/pulls/550>. Plain armhf emulation is useful for pointer-width and alignment assumptions, but the valuable tier is the hostile configuration with explicit type, signedness, alignment, and sanitizer probes. |
+| 32-bit ARM and extra portability tiers | Woodpecker portability | Covered by `.woodpecker/portability.yml` from <https://gitea.osgeo.org/postgis/postgis/pulls/516>, with hostile type-default coverage proposed in <https://gitea.osgeo.org/postgis/postgis/pulls/550>. Plain armhf emulation is useful for pointer-width and alignment assumptions, but the valuable tier is the hostile configuration with explicit type, signedness, alignment, and sanitizer probes. |
 | 64-bit ARM | Jenkins Berrie64 | Partly covered by the `arm64-berrie64-qemu` child in `.woodpecker/portability.yml` on amd64 agents through QEMU arm64 emulation. This is build, ABI, CUnit, install, and focused regression coverage, not Berrie64 parity. |
 | CodeQL | GitHub Actions | In flight as Woodpecker configuration carried separately. Woodpecker can build a CodeQL database and produce SARIF, but GitHub remains authoritative for code-scanning upload, annotations, and alert management unless Woodie artifact retention and SARIF consumption are also configured. |
 | macOS | GitHub Actions macOS | Not coverable by Woodpecker YAML on Linux. See [macOS coverage options](macos-coverage-options.md) for the actual choices, costs, licensing boundary, and current recommendation. |
@@ -162,7 +162,7 @@ Darwin coverage.
 Treat 32-bit and 64-bit ARM as separate defect classes. The 32-bit lane is most
 useful when it is hostile: explicit `char` signedness, enum-width, alignment,
-and sanitizer settings catch assumptions that amd64 and a plain Berrie rerun do
+and sanitizer settings catch assumptions that amd64 and a plain 32-bit rerun do
 not falsify.
 The 64-bit lane should be native. Berrie64's value is 64-bit ARM execution plus
diff --git a/utils/docs/ci_status/config.json b/utils/docs/ci_status/config.json
index 9d4713c3f..6804c5f9d 100644
--- a/utils/docs/ci_status/config.json
+++ b/utils/docs/ci_status/config.json
@@ -153,13 +153,6 @@
       "job_url": "https://debbie.postgis.net/view/PostGIS/job/PostGIS_Worker_Run/label=bessie/",
       "branch_parameter": "reference"
-      "name": "Jenkins / Berrie",
-      "provider": "jenkins",
-      "required": true,
-      "job_url": "https://debbie.postgis.net/view/PostGIS/job/PostGIS_Worker_Run/label=berrie/",
-      "branch_parameter": "reference"
       "name": "Jenkins / Berrie64",
diff --git a/utils/docs/tests/test_ci_status.py b/utils/docs/tests/test_ci_status.py
index 4469dbb6f..f2b78ecda 100644
--- a/utils/docs/tests/test_ci_status.py
+++ b/utils/docs/tests/test_ci_status.py
@@ -959,10 +959,10 @@ class CIStatusTest(unittest.TestCase):
     def test_jenkins_queue_prefers_current_branch_revision(self):
         check_config = {
+            "name": "Jenkins / Synthetic worker",
             "required": True,
-            "job_url": "https://ci.example.test/job/PostGIS_Worker_Run/label=berrie/",
+            "job_url": "https://ci.example.test/job/PostGIS_Worker_Run/label=synthetic/",
             "branch_parameter": "reference",
         branch = {
@@ -1004,7 +1004,7 @@ class CIStatusTest(unittest.TestCase):
             result = CI_STATUS.jenkins_queued_check(
                 check_config,
                 branch,
-                "https://ci.example.test/job/PostGIS_Worker_Run/label=berrie/",
+                "https://ci.example.test/job/PostGIS_Worker_Run/label=synthetic/",
                 timeout=5,
commit 75d0d3d44cf85d8b02a40f5d326e173a47a1547b
Date:   Tue Nov 10 04:17:47 2026 -0500
    Fix copy paste error in dev version
diff --git a/doc/development/compatibility/data/matrix.json b/doc/development/compatibility/data/matrix.json
index c1c9fc83d..06dcc50f7 100644
--- a/doc/development/compatibility/data/matrix.json
+++ b/doc/development/compatibility/data/matrix.json
@@ -867,7 +867,7 @@
       "minor": "3.8",
       "branch": "master",
-      "latest": "3.7.0dev",
+      "latest": "3.8.0dev",
       "status": "supported",
       "release_stage": "development",
       "first_release_date": "2026-10-30",
Summary of changes:
 doc/development/compatibility/data/matrix.json | 2 +-
 doc/development/testing/ci-images-runners.md   | 8 +++-----
 doc/development/testing/ci.md                  | 6 +++---
 utils/docs/ci_status/config.json               | 7 -------
 utils/docs/tests/test_ci_status.py             | 6 +++---
 5 files changed, 10 insertions(+), 19 deletions(-)
hooks/post-receive
