[SCM] PostGIS branch master updated. 3.7.0rc3-15-gbf2ddefb6
Sat Nov 14 03:34:28 PST 2026
the project "PostGIS".
       via  bf2ddefb6e9c574c21d8056097684436cea49dd0 (commit)
      from  d6ec8333c914a8bbd9aa44d03e43beae23c052d7 (commit)
revisions in full, below.
commit bf2ddefb6e9c574c21d8056097684436cea49dd0
Author: Darafei Praliaskouski <me at komzpa.net>
Date:   Sat Jun 20 20:22:57 2026 +0400
    Document RETURNS TABLE columns in manual
    Closes #1558
    Closes https://gitea.osgeo.org/postgis/postgis/pulls/419
    Closes https://github.com/postgis/postgis/pull/1060
diff --git a/NEWS b/NEWS
index 26b8eb3eb..87861a5dd 100644
--- a/NEWS
+++ b/NEWS
@@ -5,6 +5,8 @@ PostGIS 3.8.0dev
  - GT-811, Remove pointer addresses from error and notice messages
           (Andrew Kroh)
+ - #1558, GT-419, Document RETURNS TABLE signatures with returned columns
+          (Darafei Praliaskouski)
 PostGIS 3.7.0rc3
diff --git a/doc/extras_topology.xml b/doc/extras_topology.xml
index f67cb9eef..3352204d0 100644
--- a/doc/extras_topology.xml
+++ b/doc/extras_topology.xml
@@ -706,7 +706,7 @@ SELECT topology.FixCorruptTopoGeometryColumn(schema_name, table_name, feature_co
 			<refsynopsisdiv>
 				<funcsynopsis>
 					<funcprototype>
-					<funcdef>setof record <function>Populate_Topology_Layer</function></funcdef>
+					<funcdef>table(schema_name text, table_name text, feature_column text) <function>Populate_Topology_Layer</function></funcdef>
 					<paramdef></paramdef>
 					</funcprototype>
 				</funcsynopsis>
@@ -1104,7 +1104,7 @@ face without edges |   1 |
 			<refsynopsisdiv>
 				<funcsynopsis>
 					<funcprototype>
-					<funcdef>setof record <function>ValidateTopologyRelation</function></funcdef>
+					<funcdef>table(error text, layer_id int, topogeo_id bigint, element_id bigint) <function>ValidateTopologyRelation</function></funcdef>
 					<paramdef><type>varchar </type> <parameter>toponame</parameter></paramdef>
 					</funcprototype>
 				</funcsynopsis>
@@ -3348,7 +3348,7 @@ and is thus usable to build edge ring linking.
 			<refsynopsisdiv>
 				<funcsynopsis>
 					<funcprototype>
-					<funcdef>setof record <function>FindVertexSegmentPairsBelowDistance</function></funcdef>
+					<funcdef>table(seg_edge bigint, segno int, vert_edge bigint, vertno int, vert_geom geometry) <function>FindVertexSegmentPairsBelowDistance</function></funcdef>
 					<paramdef><type>varchar </type> <parameter>atopology</parameter></paramdef>
 					<paramdef><type>float8 </type> <parameter>tolerance</parameter></paramdef>
 					</funcprototype>
diff --git a/doc/reference_raster.xml b/doc/reference_raster.xml
index b95d865e3..50c58d698 100644
--- a/doc/reference_raster.xml
+++ b/doc/reference_raster.xml
@@ -3741,12 +3741,12 @@ FROM dummy_rast;</programlisting>
             <refsynopsisdiv>
                 <funcsynopsis>
                   <funcprototype>
-                        <funcdef>(1) record <function>ST_BandMetaData</function></funcdef>
+                        <funcdef>table(pixeltype text, nodatavalue double precision, isoutdb boolean, path text, outdbbandnum integer, filesize bigint, filetimestamp bigint) <function>ST_BandMetaData</function></funcdef>
                         <paramdef><type>raster </type><parameter>rast</parameter></paramdef>
                         <paramdef choice="opt"><type>integer </type><parameter>band=1</parameter></paramdef>
                   </funcprototype>
                   <funcprototype>
-                        <funcdef>(2) record <function>ST_BandMetaData</function></funcdef>
+                        <funcdef>table(bandnum integer, pixeltype text, nodatavalue double precision, isoutdb boolean, path text, outdbbandnum integer, filesize bigint, filetimestamp bigint) <function>ST_BandMetaData</function></funcdef>
                         <paramdef choice="opt"><type>integer[] </type><parameter>band</parameter></paramdef>
                   </funcprototype>
@@ -4338,7 +4338,7 @@ WHERE rid=2;</programlisting>
             <refsynopsisdiv>
                 <funcsynopsis>
                   <funcprototype>
-                    <funcdef>setof record <function>ST_PixelAsPolygons</function></funcdef>
+                    <funcdef>table(geom geometry, val double precision, x integer, y integer) <function>ST_PixelAsPolygons</function></funcdef>
                     <paramdef><type>raster </type> <parameter>rast</parameter></paramdef>
                     <paramdef choice="opt"><type>integer </type> <parameter>band=1</parameter></paramdef>
                     <paramdef choice="opt"><type>boolean </type> <parameter>exclude_nodata_value=TRUE</parameter></paramdef>
@@ -4466,7 +4466,7 @@ ORDER BY x, y;</programlisting>
             <refsynopsisdiv>
                 <funcsynopsis>
                     <funcprototype>
-                        <funcdef>setof record <function>ST_PixelAsPoints</function></funcdef>
+                        <funcdef>table(geom geometry, val double precision, x integer, y integer) <function>ST_PixelAsPoints</function></funcdef>
@@ -4604,7 +4604,7 @@ ORDER BY y, x;</programlisting>
             <refsynopsisdiv>
                 <funcsynopsis>
                     <funcprototype>
-                        <funcdef>setof record <function>ST_PixelAsCentroids</function></funcdef>
+                        <funcdef>table(geom geometry, val double precision, x integer, y integer) <function>ST_PixelAsCentroids</function></funcdef>
@@ -5902,7 +5902,7 @@ ORDER BY y;</programlisting>
             <refsynopsisdiv>
                 <funcsynopsis>
                     <funcprototype>
-                        <funcdef>setof record <function>ST_DumpValues</function></funcdef>
+                        <funcdef>table(nband integer, valarray double precision[][]) <function>ST_DumpValues</function></funcdef>
                         <paramdef>
                         </paramdef>
@@ -5999,7 +5999,7 @@ FROM foo;</programlisting>
             <refsynopsisdiv>
                 <funcsynopsis>
                     <funcprototype>
-                        <funcdef>setof record <function>ST_PixelOfValue</function></funcdef>
+                        <funcdef>table(val double precision, x integer, y integer) <function>ST_PixelOfValue</function></funcdef>
                         <paramdef>
                         </paramdef>
@@ -6014,7 +6014,7 @@ FROM foo;</programlisting>
                         </paramdef>
                     </funcprototype>
                     <funcprototype>
                         <paramdef>
                         </paramdef>
@@ -6026,7 +6026,7 @@ FROM foo;</programlisting>
                         </paramdef>
                     </funcprototype>
                     <funcprototype>
+                        <funcdef>table(x integer, y integer) <function>ST_PixelOfValue</function></funcdef>
                         <paramdef>
                         </paramdef>
@@ -6041,7 +6041,7 @@ FROM foo;</programlisting>
                         </paramdef>
                     </funcprototype>
                     <funcprototype>
                         <paramdef>
                         </paramdef>
@@ -13726,7 +13726,7 @@ FROM foo;</programlisting>
       <refsynopsisdiv>
         <funcsynopsis>
           <funcprototype>
-            <funcdef>setof record <function>ST_Contour</function></funcdef>
+            <funcdef>table(geom geometry, id integer, value float8) <function>ST_Contour</function></funcdef>
             <paramdef choice="opt"><type>integer </type><parameter>bandnumber=1</parameter></paramdef>
             <paramdef choice="opt"><type>double precision </type><parameter>level_interval=100.0</parameter></paramdef>
diff --git a/doc/reference_srs.xml b/doc/reference_srs.xml
index 8e119d87e..9c7704e56 100644
--- a/doc/reference_srs.xml
+++ b/doc/reference_srs.xml
@@ -511,7 +511,7 @@ FROM data;</programlisting>
     <refsynopsisdiv>
         <funcsynopsis>
             <funcprototype>
-                <funcdef>setof record <function>postgis_srs</function></funcdef>
+                <funcdef>table(auth_name text, auth_srid text, srname text, srtext text, proj4text text, point_sw geometry, point_ne geometry) <function>postgis_srs</function></funcdef>
                 <paramdef><type>text </type> <parameter>auth_name</parameter></paramdef>
                 <paramdef><type>text </type> <parameter>auth_srid</parameter></paramdef>
             </funcprototype>
@@ -560,7 +560,7 @@ point_ne  | POINT(-114.08 60.01)</screen>
     <refsynopsisdiv>
         <funcsynopsis>
             <funcprototype>
-                <funcdef>setof record <function>postgis_srs_all</function></funcdef>
+                <funcdef>table(auth_name text, auth_srid text, srname text, srtext text, proj4text text, point_sw geometry, point_ne geometry) <function>postgis_srs_all</function></funcdef>
                 <void/>
             </funcprototype>
         </funcsynopsis>
@@ -615,7 +615,7 @@ point_ne  | POINT(-114.08 60.01)</screen>
     <refsynopsisdiv>
         <funcsynopsis>
             <funcprototype>
-                <funcdef>setof record <function>postgis_srs_search</function></funcdef>
+                <funcdef>table(auth_name text, auth_srid text, srname text, srtext text, proj4text text, point_sw geometry, point_ne geometry) <function>postgis_srs_search</function></funcdef>
                 <paramdef><type>geometry </type> <parameter>bounds</parameter></paramdef>
                 <paramdef choice="opt"><type>text </type> <parameter>auth_name=EPSG</parameter></paramdef>
             </funcprototype>
Summary of changes:
 NEWS                     |  2 ++
 doc/extras_topology.xml  |  6 +++---
 doc/reference_raster.xml | 22 +++++++++++-----------
 doc/reference_srs.xml    |  6 +++---
 4 files changed, 19 insertions(+), 17 deletions(-)
hooks/post-receive
