[SCM] PostGIS branch master updated. 3.7.0rc3-17-gfde3f7fa5
Sat Nov 14 18:11:23 PST 2026
the project "PostGIS".
       via  fde3f7fa570d8aa1b48190dc6896e9a3527b0326 (commit)
       via  109336ade5a9335a06618699526a300d8ebe92b6 (commit)
      from  bf2ddefb6e9c574c21d8056097684436cea49dd0 (commit)
revisions in full, below.
commit fde3f7fa570d8aa1b48190dc6896e9a3527b0326
Author: Darafei Praliaskouski <me at komzpa.net>
Date:   Sun Nov 15 04:44:27 2026 +0400
    ci: enable PGDG packages for the CodeQL runner
    GitHub runner images preinstall PostgreSQL and libpq from PGDG, then
    remove its APT source. Enable that repository before adding development
    headers so APT can match the installed client and library versions.
diff --git a/.github/workflows/codeql.yml b/.github/workflows/codeql.yml
index 5cb93d298..e8d451737 100644
--- a/.github/workflows/codeql.yml
+++ b/.github/workflows/codeql.yml
@@ -72,6 +72,8 @@ jobs:
     - name: Install dependencies
       if: steps.changed-surface.outputs.skip != 'true'
       run: |
+          # Match the PGDG PostgreSQL packages preinstalled on GitHub runners.
+          sudo /usr/share/postgresql-common/pgdg/apt.postgresql.org.sh -y
           sudo apt-get update
           sudo apt-get install -y g++ autoconf automake libgeos-dev libproj-dev libgdal-dev libjson-c-dev libsfcgal-dev gettext libxml2-dev postgresql-server-dev-18 postgresql-client-18 libprotobuf-c-dev libprotoc-dev protobuf-c-compiler clang
commit 109336ade5a9335a06618699526a300d8ebe92b6
Date:   Sun Nov 15 04:41:20 2026 +0400
    ci: update CodeQL and FreeBSD to current dependencies
    Build CodeQL on Ubuntu 26.04 with its PostgreSQL 18 packages instead of
    requesting PostgreSQL 16 packages that are no longer available there.
    Use the distribution's clang package and CodeQL Action v4 with the
    existing manual build.
    Use PostgreSQL 18 on FreeBSD to match the client pulled in by GDAL.
    Mixing PG17 and PG18 makes pkg drop the server during conflict resolution,
    leaving the job without the PostgreSQL service needed for regression tests.
diff --git a/.github/workflows/ci-freebsd.yml b/.github/workflows/ci-freebsd.yml
index f0c31836d..8aefac69e 100644
--- a/.github/workflows/ci-freebsd.yml
+++ b/.github/workflows/ci-freebsd.yml
@@ -66,10 +66,11 @@ jobs:
               /etc/pkg/FreeBSD.conf
             ASSUME_ALWAYS_YES=yes pkg bootstrap -f
             env IGNORE_OSVERSION=yes pkg update -f
+            # Match the PostgreSQL client pulled in by the GDAL package.
             env IGNORE_OSVERSION=yes pkg install -y \
               autoconf automake bison ccache-static cunit docbook \
               gdal geos gmake iconv json-c libtool libxml2 libxslt \
-              pkgconf postgresql17-contrib postgresql17-server \
+              pkgconf postgresql18-contrib postgresql18-server \
               proj protobuf-c sfcgal
             projsync --system-directory --source-id us_noaa
             projsync --system-directory --source-id ch_swisstopo
index d6792c403..5cb93d298 100644
@@ -19,7 +19,8 @@ jobs:
     #   - https://gh.io/supported-runners-and-hardware-resources
     #   - https://gh.io/using-larger-runners
     # Consider using larger runners for possible analysis time improvements.
-    runs-on: ${{ (matrix.language == 'swift' && 'macos-latest') || 'ubuntu-latest' }}
+    # Keep the runner aligned with the PostgreSQL package major below.
+    runs-on: ${{ (matrix.language == 'swift' && 'macos-latest') || 'ubuntu-26.04' }}
     timeout-minutes: ${{ (matrix.language == 'swift' && 120) || 360 }}
     permissions:
       actions: read
@@ -57,9 +58,10 @@ jobs:
     # Initializes the CodeQL tools for scanning.
     - name: Initialize CodeQL
-      uses: github/codeql-action/init at v3
+      uses: github/codeql-action/init at v4
       with:
         languages: ${{ matrix.language }}
+        build-mode: manual
         # If you wish to specify custom queries, you can do so here or in a config file.
         # By default, queries listed here will override any specified in a config file.
         # Prefix the list here with "+" to use these queries and those in the config file.
@@ -71,7 +73,7 @@ jobs:
       run: |
           sudo apt-get update
-          sudo apt-get install -y g++ autoconf automake libgeos-dev libproj-dev libgdal-dev libjson-c-dev libsfcgal-dev gettext libxml2-dev postgresql-server-dev-16 postgresql-client-16 libprotobuf-c-dev libprotoc-dev protobuf-c-compiler clang-19
+          sudo apt-get install -y g++ autoconf automake libgeos-dev libproj-dev libgdal-dev libjson-c-dev libsfcgal-dev gettext libxml2-dev postgresql-server-dev-18 postgresql-client-18 libprotobuf-c-dev libprotoc-dev protobuf-c-compiler clang
     - name: Build
@@ -82,6 +84,6 @@ jobs:
     - name: Perform CodeQL Analysis
-      uses: github/codeql-action/analyze at v3
+      uses: github/codeql-action/analyze at v4
       with:
         category: "/language:${{matrix.language}}"
Summary of changes:
 .github/workflows/ci-freebsd.yml |  3 ++-
 .github/workflows/codeql.yml     | 12 ++++++++----
 2 files changed, 10 insertions(+), 5 deletions(-)
hooks/post-receive
