[PostGIS] #5796: Build without pgxs
trac at osgeo.org
Sun Nov 15 01:54:56 PST 2026
Reporter: robe | Owner: strk
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 3.7.1
Component: build | Version: master
Resolution: | Keywords:
Comment (by Darafei Praliaskouski <me@…>):
In [changeset:"1711c305b13dab8a0838d60df7d28439eeeec0b3/git" 1711c30/git]:
{{{#!CommitTicketReference repository="git"
revision="1711c305b13dab8a0838d60df7d28439eeeec0b3"
build: avoid PGXS for extension SQL bundles
Move the generated SQL extension bundle install, uninstall, and clean
rules into a local shared fragment instead of including PostgreSQL PGXS
only for those data-file targets.
This is a partial step toward removing remaining PGXS dependencies;
compiled module Makefiles and configure-time PGXS probing still require a
separate build-system replacement.
References #5796
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5796#comment:4>
