[SCM] PostGIS branch stable-3.6 updated. 3.6.4-156-gb3cd6ff2c
Sun Nov 15 01:54:57 PST 2026
the project "PostGIS".
The branch, stable-3.6 has been updated
       via  b3cd6ff2cedb2b17b11407c64b532946bf472619 (commit)
       via  5d9f0f30edb001c8c3d94af148113fa39342aa05 (commit)
       via  536718423a3ee58564455f53e99b3c048c13525f (commit)
      from  82b51ba31c5303c600d9bb6272ed4e94c6843115 (commit)
revisions in full, below.
commit b3cd6ff2cedb2b17b11407c64b532946bf472619
Author: Darafei Praliaskouski <me at komzpa.net>
Date:   Sun Nov 15 13:07:24 2026 +0400
    Correct column-list comment spelling
diff --git a/loader/shp2pgsql-core.h b/loader/shp2pgsql-core.h
index 905f92253..748d4773a 100644
--- a/loader/shp2pgsql-core.h
+++ b/loader/shp2pgsql-core.h
@@ -192,7 +192,7 @@ typedef struct shp_loader_state
 	/* Pointer to an array of PostgreSQL field types */
 	char **pgfieldtypes;
-	/* String containing colume name list in the form "col1, col2, col3 ... , colN" */
+	/* String containing column name list in the form "col1, col2, col3 ... , colN" */
 	char *col_names;
 	/* String containing the PostGIS geometry type, e.g. POINT, POLYGON etc. */
commit 5d9f0f30edb001c8c3d94af148113fa39342aa05
Date:   Sun Nov 8 10:31:53 2026 +0400
    News entry for GH-1178
diff --git a/NEWS b/NEWS
index 6f085e24b..1923c6d5c 100644
--- a/NEWS
+++ b/NEWS
@@ -3,6 +3,8 @@ PostGIS 3.6.5dev
 * Fixes *
+- GH-1178, Avoid NULL dereferences when column-map allocation fails and make
+  partial column-map cleanup safe (Maksim Korotkov)
 - GT-779, [raster] Make postgis.enable_outdb_rasters=off enforce offline-band
   metadata and pixel-read restrictions after upgrade
   (reported by Sarath Kumar, IITM Pravartak Security Team;
commit 536718423a3ee58564455f53e99b3c048c13525f
Author: Maksim Korotkov <m.korotkov at postgrespro.ru>
Date:   Mon Sep 7 18:06:41 2026 +0300
    loader: check column map allocations and fix cleanup
    Check the return of malloc/calloc in colmap_read and bail out with an
    error instead of dereferencing NULL on the pgfieldnames/dbffieldnames
    array and per-field string allocations. The column map arrays are now
    calloc'd so unused slots are NULL-initialized.
    Rework colmap_clean to be safe on partial state: early-return on NULL,
    free the field-name arrays unconditionally (free(NULL) is valid), and
    reset the map via colmap_init so the map is reusable and a subsequent
    ShpLoaderDestroy colmap_clean call stays safe. The calloc-failure path
    resets map->size first so the cleanup loop doesn't index a half-allocated
    array.
    Signed-off-by: Maksim Korotkov <m.korotkov at postgrespro.ru>
    Closes https://github.com/postgis/postgis/pull/1178 for PostGIS 3.6
    (cherry picked from commit 6a9387914570bcdcf6a4a4b4557a17a9c6abeb28)
diff --git a/loader/shpcommon.c b/loader/shpcommon.c
index a27d45dc4..0c82089f3 100644
--- a/loader/shpcommon.c
+++ b/loader/shpcommon.c
@@ -171,18 +171,21 @@ void
 colmap_clean(colmap *map)
 	int i;
-	if (map != NULL){
-		if (map->size)
+	if (map == NULL)
+		return;
+	if (map->size)
+		for (i = 0; i < map->size; i++)
-			for (i = 0; i < map->size; i++)
-				if (map->pgfieldnames[i]) free(map->pgfieldnames[i]);
-				if (map->dbffieldnames[i]) free(map->dbffieldnames[i]);
-			free(map->pgfieldnames);
-			free(map->dbffieldnames);
+			free(map->pgfieldnames[i]);
+			free(map->dbffieldnames[i]);
+	free(map->pgfieldnames);
+	free(map->dbffieldnames);
+	colmap_init(map);
 const char *
@@ -232,13 +235,30 @@ colmap_read(const char *filename, colmap *map, char *errbuf, size_t errbuflen)
     return 0;
+  /* Release any prior contents and reset the map so this call is safe to
+   * reuse on the same struct (and so ++map->size below starts from zero) */
+  colmap_clean(map);
   /* First count how many columns we have... */
   while (fgets(linebuffer, 1024, fptr) != NULL) ++map->size;
+  if (!map->size)
+    fclose(fptr);
+    return 1;
   /* Now we know the final size, allocate the arrays and load the data */
   fseek(fptr, 0, SEEK_SET);
-  map->pgfieldnames = (char **)malloc(sizeof(char *) * map->size);
-  map->dbffieldnames = (char **)malloc(sizeof(char *) * map->size);
+  map->pgfieldnames = (char **)calloc(map->size, sizeof(char *));
+  map->dbffieldnames = (char **)calloc(map->size, sizeof(char *));
+  if (!map->pgfieldnames || !map->dbffieldnames)
+    map->size = 0;
+    fclose(fptr);
+    snprintf(errbuf, errbuflen, _("ERROR: Unable to allocate memory for column map file %s"), filename);
+    return 0;
   /* Read in a line at a time... */
   curmapsize = 0;
@@ -251,6 +271,13 @@ colmap_read(const char *filename, colmap *map, char *errbuf, size_t errbuflen)
     /* Allocate memory and copy the string ensuring it is terminated */
     map->pgfieldnames[curmapsize] = malloc(fieldnamesize + 1);
+    if (!map->pgfieldnames[curmapsize])
+      fclose(fptr);
+      return 0;
     strncpy(map->pgfieldnames[curmapsize], tmpstr, fieldnamesize);
     map->pgfieldnames[curmapsize][fieldnamesize] = '\0';
@@ -263,6 +290,13 @@ colmap_read(const char *filename, colmap *map, char *errbuf, size_t errbuflen)
     map->dbffieldnames[curmapsize] = malloc(fieldnamesize + 1);
+    if (!map->dbffieldnames[curmapsize])
+      fclose(fptr);
+      return 0;
     strncpy(map->dbffieldnames[curmapsize], tmpstr, fieldnamesize);
     map->dbffieldnames[curmapsize][fieldnamesize] = '\0';
Summary of changes:
 NEWS                    |  2 ++
 loader/shp2pgsql-core.h |  2 +-
 loader/shpcommon.c      | 56 +++++++++++++++++++++++++++++++++++++++----------
 3 files changed, 48 insertions(+), 12 deletions(-)
hooks/post-receive
