[PostGIS] #6140: ST_AddNodeModFace creates invalid topology
trac at osgeo.org
Fri Oct 2 02:00:24 PDT 2026
Reporter: strk | Owner: strk
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 3.6.5
Component: topology | Version: 3.6.x
Keywords: robustness |
Spinoff of #6129: ST_AddNodeModFace creates invalid topology:
SELECT DropTopology('ttt');
SELECT NULL FROM CreateTopology('ttt');
SELECT NULL FROM ST_AddIsoNode('ttt', 0,
'01010000005163B45884333540352259FDE66A5140'); -- start node of edge 1
'0101000000685E205B88333540B7363CF4E66A5140'); -- start node of edge 2
'0101000000831D215B88333540107B41F4E66A5140'); -- end node of both edges
SELECT NULL FROM ST_AddEdgeModFace('ttt', 1, 3,
'0102000000030000005163B45884333540352259FDE66A51406043FEC3BA333540C0BFF081E66A5140831D215B88333540107B41F4E66A5140');
SELECT NULL FROM ST_AddEdgeModFace('ttt', 2, 3,
'010200000002000000685E205B88333540B7363CF4E66A5140831D215B88333540107B41F4E66A5140');
-- this edge crosses the previous
SELECT 'invalidities', * FROM ValidateTopology('ttt'); -- Requires
https://trac.osgeo.org/postgis/ticket/6138 fix to see this
Note in order to spot the invalidity we need the fix for #6138
Ticket URL: <https://trac.osgeo.org/postgis/ticket/6140>
