[SCM] PostGIS branch master updated. 3.7.0rc1-84-g8c02deb33
git at osgeo.org
git at osgeo.org
Fri Oct 2 07:42:35 PDT 2026
the project "PostGIS".
via 8c02deb339a32ccf4a148ce2ada62480ce8d8c40 (commit)
from 217cc8b33941f034b81901c74544ca5f57fcab97 (commit)
revisions in full, below.
commit 8c02deb339a32ccf4a148ce2ada62480ce8d8c40
Author: Sandro Santilli <strk at kbt.io>
Date: Fri Oct 2 16:42:11 2026 +0200
Fix issue reference
diff --git a/topology/test/regress/topogeo_addlinestring.sql b/topology/test/regress/topogeo_addlinestring.sql
index caef2a21f..56ab6bdab 100644
--- a/topology/test/regress/topogeo_addlinestring.sql
+++ b/topology/test/regress/topogeo_addlinestring.sql
@@ -334,14 +334,14 @@ SELECT 't3412.end.error', * FROM topology.ValidateTopology('bug3412');
SELECT NULL FROM DropTopology('bug3412');
-- See http://trac.osgeo.org/postgis/ticket/3711
-SELECT 't3371.start', topology.CreateTopology('bug3711', 0, 0, true) > 1;
-SELECT 't3371.L1', topology.TopoGeo_AddLineString('bug3711',
+SELECT 't3711.start', topology.CreateTopology('bug3711', 0, 0, true) > 1;
+SELECT 't3711.L1', topology.TopoGeo_AddLineString('bug3711',
'LINESTRING (618369 4833784 0.88, 618370 4833784 1.93, 618370 4833780 1.90)'
::geometry, 0);
-SELECT 't3371.L2', count(*) FROM topology.TopoGeo_AddLineString( 'bug3711',
+SELECT 't3711.L2', count(*) FROM topology.TopoGeo_AddLineString( 'bug3711',
'LINESTRING (618370 4833780 1.92, 618370 4833784 1.90, 618371 4833780 1.93)'
::geometry, 0);
-SELECT 't3371.end', topology.DropTopology('bug3711');
+SELECT 't3711.end', topology.DropTopology('bug3711');
-- See http://trac.osgeo.org/postgis/ticket/3838
SELECT 't3838.start', topology.CreateTopology('bug3838') > 1;
diff --git a/topology/test/regress/topogeo_addlinestring_expected b/topology/test/regress/topogeo_addlinestring_expected
index aebefa2c6..22de16a2c 100644
--- a/topology/test/regress/topogeo_addlinestring_expected
+++ b/topology/test/regress/topogeo_addlinestring_expected
@@ -184,10 +184,10 @@ t3402.end|Topology 'bug3402' dropped
t3412.start|t
t3412.L1|1
t3412.L2|t
-t3371.start|t
-t3371.L1|1
-t3371.L2|2
-t3371.end|Topology 'bug3711' dropped
+t3711.start|t
+t3711.L1|1
+t3711.L2|2
+t3711.end|Topology 'bug3711' dropped
t3838.start|t
t3838.L1|1
t3838.L2|t
Summary of changes:
topology/test/regress/topogeo_addlinestring.sql | 8 ++++----
topology/test/regress/topogeo_addlinestring_expected | 8 ++++----
2 files changed, 8 insertions(+), 8 deletions(-)
hooks/post-receive
