[PostGIS] #6142: postgis_topology proper fix for topogeometry corruption
PostGIS trac at osgeo.org
Mon Oct 5 07:34:40 PDT 2026
 Reporter:  robe      |      Owner:  strk
     Type:  defect    |     Status:  new
 Priority:  medium    |  Milestone:  PostGIS 3.7.1
Component:  topology  |    Version:  3.6.x
 Keywords:            |
 As discussed with Andreas on IRC, the  changing system catalogs for
 topogeom was just sloppy and
 https://postgis.net/docs/FixCorruptTopoGeometryColumn.html is a messy
 solution to upgrade and corrupting the catalog on upgrade with the
 expectation users will run the fix before hand is sloppy.
 He proposed add another id attribute to topogeometry type perhaps calling
 it id4 or some such thing and running upgrade as part of it.
 Two options come to mind which I assume are both possibly
 Option 1:
 1) rename a int4 id to id4.
 2) Create a new id field
 3) copy the id4 to id values, copy the values to the new id, and then drop
 the id4.
 Option 2:
 Alternative to that which would not require slow extension upgrade,
 Do 1,2  and change functions to use which ever one is populated behind the
 scenes.
 In theory we wouldn't need to change signatures even in case of option 2,
 but that requires a bit more testing and checking.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/6142>
