[SCM] PostGIS branch master updated. 3.7.0rc1-101-gb4c17bad6
git at osgeo.org
git at osgeo.org
Thu Oct 8 22:30:20 PDT 2026
the project "PostGIS".
via b4c17bad6b529053086d21eaaf294eeb28c07466 (commit)
via faf08233c9be412ab11649484182f9876d65b0d9 (commit)
from fdfed4b3ae6100efdfba36576cc80414552348a7 (commit)
revisions in full, below.
commit b4c17bad6b529053086d21eaaf294eeb28c07466
Author: Regina Obe <lr at pcorp.us>
Date: Fri Oct 9 01:29:57 2026 -0400
Fix credits link
add credits for Maxim Korotkov
diff --git a/CREDITS b/CREDITS
index 268a912d7..4f1add896 100644
--- a/CREDITS
+++ b/CREDITS
@@ -1,4 +1,4 @@
For updated credits, see the PostGIS manual.
Offline: see doc/README
-Online: https://postgis.net/docs/manual-dev/postgis_introduction.html#credits
+Online: https://postgis.net/docs/manual-dev/en/postgis_credits.html
diff --git a/doc/credits.xml b/doc/credits.xml
index 86f75f71d..70e15cebc 100644
--- a/doc/credits.xml
+++ b/doc/credits.xml
@@ -390,6 +390,7 @@
<member>Matthias Bay</member>
<member>Maurício Carvalho Mathias de Paulo</member>
<member>Maxim Kochetkov</member>
+ <member>Maxim Korotkov</member>
<member>Maxime Guillaud</member>
<member>Maxime van Noppen</member>
<member>Maxime Schoemans</member>
commit faf08233c9be412ab11649484182f9876d65b0d9
Author: Maksim Korotkov <m.korotkov at postgrespro.ru>
Date: Tue Sep 8 16:10:36 2026 +0300
raster: check array_range allocation and free on the error branch
rtalloc in array_range could return NULL and be dereferenced when
filling the range array; check the result and return the existing
error code (0) instead. Also rtdealloc the already-allocated range in
the (currently unreachable) else branch before nulling the pointer, so
no allocation leaks on the error path.
Signed-off-by: Maksim Korotkov <m.korotkov at postgrespro.ru>
Closes https://github.com/postgis/postgis/pull/1179
for PostGIS 3.7.0
diff --git a/raster/loader/raster2pgsql.c b/raster/loader/raster2pgsql.c
index 9ed52e674..6e9a5953d 100644
--- a/raster/loader/raster2pgsql.c
+++ b/raster/loader/raster2pgsql.c
@@ -142,6 +142,12 @@ array_range(int min, int max, int step, int **range, uint32_t *len) {
*len = (uint32_t) ((abs(max - min) + 1 + (step / 2)) / step);
*range = rtalloc(sizeof(int) * *len);
+ if (!*range)
+ *len = 0;
+ return 0;
if (min < max) {
for (i = min, j = 0; i <= max; i += step, j++)
(*range)[j] = i;
@@ -156,6 +162,7 @@ array_range(int min, int max, int step, int **range, uint32_t *len) {
else {
*len = 0;
+ rtdealloc(*range);
*range = NULL;
return 0;
Summary of changes:
CREDITS | 2 +-
doc/credits.xml | 1 +
raster/loader/raster2pgsql.c | 7 +++++++
3 files changed, 9 insertions(+), 1 deletion(-)
hooks/post-receive
