[SCM] PostGIS branch master updated. 3.7.0rc1-112-g38778320c
Sat Oct 17 00:18:26 PDT 2026
the project "PostGIS".
       via  38778320c821b872c664ad47d6b0136fc9f81fcf (commit)
       via  1bfb16afc99c47121ccb4385ed8e475f6953d15a (commit)
       via  3dcb621861ba8549465e1aad97359cd0e71c7161 (commit)
      from  c3a576e61ddfb7fb2c81edca3a3091183417c432 (commit)
revisions in full, below.
commit 38778320c821b872c664ad47d6b0136fc9f81fcf
Author: Regina Obe <lr at pcorp.us>
Date:   Sat Oct 17 03:18:14 2026 -0400
    Update release and translation template
diff --git a/doc/po/templates/postgis-manual.pot b/doc/po/templates/postgis-manual.pot
index 5a60449c2..1e6557a8c 100644
--- a/doc/po/templates/postgis-manual.pot
+++ b/doc/po/templates/postgis-manual.pot
@@ -6,7 +6,7 @@ msgid ""
 msgstr ""
 "Project-Id-Version: PACKAGE VERSION\n"
 "Report-Msgid-Bugs-To: https://bugs.kde.org\n"
-"POT-Creation-Date: 2026-08-04 15:37+0000\n"
+"POT-Creation-Date: 2026-10-17 07:16+0000\n"
 "PO-Revision-Date: YEAR-MO-DA HO:MI+ZONE\n"
 "Last-Translator: FULL NAME <EMAIL at ADDRESS>\n"
 "Language-Team: LANGUAGE <kde-i18n-doc at kde.org>\n"
@@ -3356,7 +3356,9 @@ msgstr ""
 #. Tag: para
 #, no-c-format
-msgid ", <xref linkend=\"GetNodeEdges\"/>"
+msgid ""
+", <xref linkend=\"GetNodeEdges\"/> <xref linkend=\"getfaceedges_returntype\"/"
 msgstr ""
 #. Tag: refpurpose
@@ -7663,6 +7665,69 @@ msgstr ""
 msgid "&sqlmm_compliant; SQL-MM 3: 5.1.8"
 msgstr ""
+#. Tag: refpurpose
+#, no-c-format
+msgid "Report locations of self-intersection or self-tangency, if any."
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"Returns a <varname>simple_detail</varname> row, containing a boolean "
+"(<varname>simple</varname>) stating if a geometry is simple and a geometry "
+"(<varname>location</varname>) pointing out where it is non-simple."
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"The optional <varname>findAllLocations</varname> parameter can be set to 1 "
+"to report all non-simple locations, rather than just one."
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid "The optional <varname>boundaryNodeRule</varname> values are:"
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"<code>1</code>: <emphasis role=\"bold\">OGC-Mod2</emphasis> - line endpoints "
+"are in the Boundary if they occur an odd number of times. This is the rule "
+"defined by the OGC SFS standard, and is the default for <function>ST_Relate</"
+"function>."
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"<code>2</code>: <emphasis role=\"bold\">Endpoint</emphasis> - all endpoints "
+"are in the Boundary."
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"<code>3</code>: <emphasis role=\"bold\">MultivalentEndpoint</emphasis> - "
+"endpoints are in the Boundary if they occur more than once. In other words, "
+"the boundary is all the \"attached\" or \"inner\" endpoints (but not the "
+"\"unattached/outer\" ones)."
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"<code>4</code>: <emphasis role=\"bold\">MonovalentEndpoint</emphasis> - "
+"endpoints are in the Boundary if they occur only once. In other words, the "
+"boundary is all the \"unattached\" or \"outer\" endpoints."
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid "Availability: 3.7.0"
+msgstr ""
 #. Tag: refpurpose
 #, no-c-format
 msgid "Returns the M coordinate of a Point."
@@ -8597,11 +8662,6 @@ msgid ""
 "if the input is NULL."
 msgstr ""
-#. Tag: para
-#, no-c-format
-msgid "Availability: 3.7.0"
-msgstr ""
 #. Tag: para
 #, no-c-format
 msgid "This example extracts control points from a NURBS curve."
@@ -31467,39 +31527,6 @@ msgid ""
 "The <varname>boundaryNodeRule</varname> values are:"
 msgstr ""
-#. Tag: para
-#, no-c-format
-msgid ""
-"<code>1</code>: <emphasis role=\"bold\">OGC-Mod2</emphasis> - line endpoints "
-"are in the Boundary if they occur an odd number of times. This is the rule "
-"defined by the OGC SFS standard, and is the default for <function>ST_Relate</"
-"function>."
-msgstr ""
-#. Tag: para
-#, no-c-format
-msgid ""
-"<code>2</code>: <emphasis role=\"bold\">Endpoint</emphasis> - all endpoints "
-"are in the Boundary."
-msgstr ""
-#. Tag: para
-#, no-c-format
-msgid ""
-"<code>3</code>: <emphasis role=\"bold\">MultivalentEndpoint</emphasis> - "
-"endpoints are in the Boundary if they occur more than once. In other words, "
-"the boundary is all the \"attached\" or \"inner\" endpoints (but not the "
-"\"unattached/outer\" ones)."
-msgstr ""
-#. Tag: para
-#, no-c-format
-msgid ""
-"<code>4</code>: <emphasis role=\"bold\">MonovalentEndpoint</emphasis> - "
-"endpoints are in the Boundary if they occur only once. In other words, the "
-"boundary is all the \"unattached\" or \"outer\" endpoints."
-msgstr ""
 #. Tag: para
 #, no-c-format
 msgid "This function is not in the OGC spec, but is implied. see s2.1.13.2"
@@ -35940,6 +35967,15 @@ msgid ""
 "2.3+ is needed. Python 3 is a new requirement to build the documentation."
 msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"Visual examples in the docs are off by default. To build docs with them, "
+"configure with `--with-visual-examples` and make sure you have a running "
+"PostgreSQL instance; they are then generated automatically when building the "
+"docs (or explicitly with `make -C regress visual-examples`)."
+msgstr ""
 #. Tag: title
 #, no-c-format
 msgid "Breaking Changes"
@@ -36189,6 +36225,15 @@ msgid ""
 "(Darafei Praliaskouski)"
 msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"<link xlink:href=\"https://git.osgeo.org/postgis/postgis/pull/806\">GT-806</"
+"link>, <link xlink:href=\"https://trac.osgeo.org/postgis/"
+"ticket/6124\">#6124</link> --with-visual-examples opt-in configure switch to "
+"build dynamic images (Regina Obe)"
+msgstr ""
 #. Tag: title
 #, no-c-format
 msgid "Enhancements"
diff --git a/doc/release_notes.xml b/doc/release_notes.xml
index 2c134e4ae..719e685fa 100644
--- a/doc/release_notes.xml
+++ b/doc/release_notes.xml
@@ -5,9 +5,14 @@
     <title>PostGIS 3.7.0</title>
     <subtitle>2026/xx/xx</subtitle>
     <para>This version requires GEOS 3.10+, PostgreSQL 14-19beta3, Proj 6.1+, and libgmp.
-    To take advantage of all postgis extension features, GEOS 3.15+ is needed.
-    To take advantage of all postgis_sfcgal extension features SFCGAL 2.3+ is needed.
-    Python 3 is a new requirement to build the documentation.</para>
+        To take advantage of all postgis extension features, GEOS 3.15+ is needed.
+        To take advantage of all postgis_sfcgal extension features SFCGAL 2.3+ is needed.
+        Python 3 is a new requirement to build the documentation.</para>
+        <para>Visual examples in the docs are off by default. To build docs with them,
+        configure with `--with-visual-examples` and make sure you have a running
+        PostgreSQL instance; they are then generated automatically when building
+        the docs (or explicitly with `make -C regress visual-examples`).</para>
     <simplesect>
       <title>Breaking Changes</title>
       <para><link xlink:href="https://trac.osgeo.org/postgis/ticket/5688">#5688</link>, [topology] topology building functions now interpret tolerance 0 (old default) to really mean 0 and want -1 (new default) to mean "use topology precision" (Sandro Santilli)</para>
@@ -44,6 +49,8 @@
       <para><link xlink:href="https://trac.osgeo.org/postgis/ticket/1291">#1291</link>, ST_MakePolygon support for curved rings (Darafei Praliaskouski)</para>
       <para><link xlink:href="https://gitea.osgeo.org/postgis/postgis/pulls/270">GT-270</link>, Add NURBSCurve (Loïc Bartoletti)</para>
       <para><link xlink:href="https://trac.osgeo.org/postgis/ticket/2863">#2863</link>, Add ST_XSize, ST_YSize, ST_ZSize, and ST_MSize dimension helpers (Darafei Praliaskouski)</para>
+      <para><link xlink:href="https://git.osgeo.org/postgis/postgis/pull/806">GT-806</link>, <link xlink:href="https://trac.osgeo.org/postgis/ticket/6124">#6124</link> --with-visual-examples opt-in
+           configure switch to build dynamic images (Regina Obe)</para>
     </simplesect>
     <simplesect>
       <title>Enhancements</title>
commit 1bfb16afc99c47121ccb4385ed8e475f6953d15a
Date:   Sat Oct 17 02:05:25 2026 -0400
    Fixes for windows
    Closes https://gitea.osgeo.org/postgis/postgis/pulls/806
    Closes #6124
diff --git a/NEWS b/NEWS
index 5140c524a..1751d30cc 100644
--- a/NEWS
+++ b/NEWS
@@ -1,5 +1,5 @@
-PostGIS 3.7.0
-2026/xx/xx
+PostGIS 3.7.0rc3
+2026/10/xx
@@ -28,7 +28,7 @@ the docs (or explicitly with `make -C regress visual-examples`).
  - GH-848, CG_AlphaShape now returns a MultiPolygon (Jean Felder)
  - [docs] Python 3 and an SVG rasterizer (rsvg-convert preferred,
           GraphicsMagick or ImageMagick supported) now required for doc
-          building (Darafei Praliaskouski)
+          dynamic image rendering (Darafei Praliaskouski)
 * New Features *
@@ -68,6 +68,8 @@ the docs (or explicitly with `make -C regress visual-examples`).
            axis to the boundary. (Loïc Bartoletti)
  - GH-871, Add CG_PolygonRepair (Loïc Bartoletti)
  - GH-872, SFCGAL roof generation algorithms (Loïc Bartoletti)
+ - GT-806, #6124 --with-visual-examples opt-in
 * Enhancements *
diff --git a/ci/winnie/winnie_common.sh b/ci/winnie/winnie_common.sh
index 409bb678c..19795c741 100644
--- a/ci/winnie/winnie_common.sh
+++ b/ci/winnie/winnie_common.sh
@@ -9,7 +9,8 @@ export PROJECTS=/projects
 # Don't convert paths
 # See https://trac.osgeo.org/postgis/ticket/5436#comment:5
 export MSYS2_ARG_CONV_EXCL=/config/tags
-export XML_CATALOG_FILES="/projects/docbook/docbook-5.0.1/catalog.xml"
+export XML_CATALOG_FILES="/projects/dockbook/docbook-xsl/catalog.xml"
+export XLSBASE="/projects/dockbook/docbook-xsl"
 if  [[ "${OVERRIDE}" == '' ]] ; then
 	export GEOS_VER=3.15.0
diff --git a/utils/docs/tests/test_postgis_exampletest.py b/utils/docs/tests/test_postgis_exampletest.py
index abf114c58..33eb76da0 100644
--- a/utils/docs/tests/test_postgis_exampletest.py
+++ b/utils/docs/tests/test_postgis_exampletest.py
@@ -21,6 +21,18 @@ sys.path.insert(0, str(Path(__file__).resolve().parents[1]))
 from postgis_exampletest import ExampleTester, QueryRows, parse_source_example
+ at contextlib.contextmanager
+def open_tmp_xml():
+    # Windows denies reopening a NamedTemporaryFile while its delete-on-close
+    # handle is open, so create it with delete=False and unlink it ourselves.
+    handle = tempfile.NamedTemporaryFile("w", suffix=".xml", encoding="utf-8", delete=False)
+    try:
+        yield handle
+    finally:
+        handle.close()
+        os.unlink(handle.name)
 def xyz_vertices(points, ring=False):
     return [
         {"path": [1, index] if ring else [index], "point": point}
@@ -264,7 +276,7 @@ SELECT 'POINT(1 2)', $$LINESTRING(0 0,1 1)$$,
     </refsection>
   </refentry>
 </book>"""
-        with tempfile.NamedTemporaryFile("w", suffix=".xml", encoding="utf-8") as source:
+        with open_tmp_xml() as source:
             source.write(xml)
             source.flush()
             example = ExampleTester(source.name).examples()[0]
@@ -283,7 +295,7 @@ SELECT 'POINT(1 2)', $$LINESTRING(0 0,1 1)$$,
     </refsection>
   </refentry>
 </book>"""
             source.write(xml)
             source.flush()
@@ -299,7 +311,7 @@ SELECT 'POINT(1 2)', $$LINESTRING(0 0,1 1)$$,
     </refsection>
   </refentry>
 </book>"""
             source.write(xml)
             source.flush()
@@ -314,7 +326,7 @@ SELECT 'POINT(1 2)', $$LINESTRING(0 0,1 1)$$,
     </refsection>
   </refentry>
 </book>"""
             source.write(xml)
             source.flush()
@@ -336,7 +348,7 @@ SELECT 'POINT(1 2)', $$LINESTRING(0 0,1 1)$$,
     </refsection>
   </refentry>
 </book>"""
                     source.write(xml)
                     source.flush()
@@ -353,7 +365,7 @@ SELECT 'POINT(1 2)', $$LINESTRING(0 0,1 1)$$,
     </refsection>
   </refentry>
 </book>"""
             source.write(xml)
             source.flush()
@@ -370,7 +382,7 @@ SELECT 'POINT(1 2)', $$LINESTRING(0 0,1 1)$$,
     </refsection>
   </refentry>
 </book>"""
             source.write(xml)
             source.flush()
@@ -397,7 +409,7 @@ SELECT 'POINT(1 2)', $$LINESTRING(0 0,1 1)$$,
     <screen>1</screen>
   </refsection></refentry>
 </book>"""
             source.write(xml)
             source.flush()
             tester = ExampleTester(source.name)
@@ -445,7 +457,7 @@ SELECT 'POINT(1 2)', $$LINESTRING(0 0,1 1)$$,
     <screen>dummy</screen>
 </book>"""
             source.write(xml)
             source.flush()
@@ -465,7 +477,7 @@ SELECT 'POINT(1 2)', $$LINESTRING(0 0,1 1)$$,
 </book>"""
             source.write(xml)
             source.flush()
commit 3dcb621861ba8549465e1aad97359cd0e71c7161
Date:   Tue Oct 13 00:34:57 2026 -0400
    - By default dynamic image building is turned off
     - New configure switch --with-visual-examples is required to enable
       dynamic image building.
     - Add new switch to doc-building cis and add new make visual example target
     - Add conditional WITH_VISUAL_EXAMPLES env to winnie
diff --git a/.woodpecker/docs.yml b/.woodpecker/docs.yml
index 4caca002b..2b2818ead 100644
--- a/.woodpecker/docs.yml
+++ b/.woodpecker/docs.yml
@@ -50,7 +50,7 @@ steps:
     commands:
       - ./autogen.sh
       - mkdir -p build-docs && cd build-docs
-      - ../configure --with-pgconfig=/usr/lib/postgresql/18/bin/pg_config --without-protobuf --without-raster
+      - ../configure --with-pgconfig=/usr/lib/postgresql/18/bin/pg_config --without-protobuf --without-raster --with-visual-examples
       - make postgis_revision.h
       - . ../ci/parallel-jobs.sh
       - export POSTGIS_BUILD_JOBS=$$(postgis_ci_parallel_jobs)
index aeb7af2aa..5140c524a 100644
--- a/NEWS
+++ b/NEWS
@@ -6,10 +6,10 @@ To take advantage of all postgis extension features, GEOS 3.15+ is needed.
-To build docs, first run visual examples and make sure you have a running
-PostgreSQL instance.
-`make -C regress visual-examples`
+Visual examples in the docs are off by default. To build docs with them,
+configure with `--with-visual-examples` and make sure you have a running
+PostgreSQL instance; they are then generated automatically when building
+the docs (or explicitly with `make -C regress visual-examples`).
 * Breaking Changes *
diff --git a/ci/debbie/postgis_release_docs.sh b/ci/debbie/postgis_release_docs.sh
index 91fe4579a..2b90fa1fa 100644
--- a/ci/debbie/postgis_release_docs.sh
+++ b/ci/debbie/postgis_release_docs.sh
@@ -180,6 +180,7 @@ LDFLAGS="-L${SFCGALPATH}/lib -L${PROJPATH}/lib -L${GDALPATH}/lib -L${GEOSPATH}/l
   --with-gdalconfig=${GDAL_CONFIG} \
   --with-projdir=${PROJPATH} \
   --with-sfcgal=${SFCGAL_CONFIG} \
+  --with-visual-examples \
   --with-raster \
   --htmldir "${HTML_DIR}" \
   --docdir "${STUFF_DIR}"
diff --git a/ci/winnie/regress_postgis.sh b/ci/winnie/regress_postgis.sh
index 2c48f998b..107b38f6c 100644
--- a/ci/winnie/regress_postgis.sh
+++ b/ci/winnie/regress_postgis.sh
@@ -70,6 +70,10 @@ if [ "${REGRESS_WITHOUT_RASTER:-0}" == "1" ]; then
    EXTRA_CONFIGURE_ARGS="${EXTRA_CONFIGURE_ARGS} --without-raster"
 fi
+if [ "${WITH_VISUAL_EXAMPLES:-0}" == "1" ]; then
+   EXTRA_CONFIGURE_ARGS="${EXTRA_CONFIGURE_ARGS} --with-visual-examples"
+fi
 #CPPFLAGS="-I${PGPATH}/include -I${PROJECTS}/rel-libiconv-${ICON_VER}w${OS_BUILD}${GCC_TYPE}/include" \
 #CFLAGS="-Wall -fno-omit-frame-pointer"
index c264be2bc..409bb678c 100644
@@ -58,6 +58,10 @@ fi;
 echo "LZ4_VER ${LZ4_VER}"
+if  [[ "${WITH_VISUAL_EXAMPLES}" == '' ]] ; then
+  export WITH_VISUAL_EXAMPLES=0
+fi;
 if  [[ "${REGRESS_WITHOUT_TOPOLOGY}" == '' ]] ; then
   export REGRESS_WITHOUT_TOPOLOGY=0
 fi;
diff --git a/configure.ac b/configure.ac
index 7371941f1..8bda1ec8a 100644
--- a/configure.ac
+++ b/configure.ac
@@ -243,9 +243,24 @@ fi
 AC_PATH_PROG([PYTHON3], [python3], [])
 if test "x$PYTHON3" = "x"; then
 	AC_MSG_WARN([python3 is not installed so documentation visual examples cannot be generated])
-	AC_MSG_WARN([documentation build will fail: run 'make -C regress visual-examples' first])
 fi
+dnl Visual examples are rendered from the manual by running the example
+dnl queries against a staged PostGIS build, so they are opt-in.
+VISUAL_EXAMPLES="no"
+AC_ARG_WITH([visual-examples],
+	[AS_HELP_STRING([--with-visual-examples],
+		[Generate visual example images when building the documentation (default is no)])],
+	[], [with_visual_examples="no"])
+if test "x$with_visual_examples" != "xno"; then
+	if test "x$PYTHON3" = "x"; then
+		AC_MSG_ERROR([--with-visual-examples requires python3])
+	fi
+	VISUAL_EXAMPLES="yes"
+fi
+AC_SUBST([VISUAL_EXAMPLES])
 AC_PATH_PROG([XML2POT], [xml2pot], [])
 if test "x$XML2POT" = "x"; then
 	AC_MSG_WARN([xml2pot is not installed so translation template cannot be updated])
@@ -2003,6 +2018,7 @@ if test "x$TOPOLOGY" = "xtopology"; then
 else
     AC_MSG_RESULT([  PostGIS Topology:                   disabled])
 fi
+AC_MSG_RESULT([  Doc visual examples:                ${VISUAL_EXAMPLES}])
 if test "x$SFCGAL" = "xsfcgal"; then
     AC_MSG_RESULT([  SFCGAL support:                     enabled])
 else
diff --git a/doc/Makefile.in b/doc/Makefile.in
index a0e186e3b..911ff8478 100644
--- a/doc/Makefile.in
+++ b/doc/Makefile.in
@@ -50,8 +50,14 @@ DOCSUFFIX=-en
 html_builddir=$(abs_builddir)/html
 images_builddir=$(html_builddir)/images
 pdf_images_builddir=$(abs_builddir)/pdf/images
+VISUAL_EXAMPLES=@VISUAL_EXAMPLES@
+ifeq ($(VISUAL_EXAMPLES),yes)
 visual_examples_manifest=$(images_builddir)/visual-examples/manifest.xml
 visual_examples_inputs=$(wildcard $(visual_examples_manifest) $(images_builddir)/visual-examples/*.svg)
+else
+visual_examples_manifest=
+visual_examples_inputs=
+endif
 ifneq (,$(findstring dev,$(POSTGIS_MICRO_VERSION)))
   POSTGIS_DOWNLOAD_URL=https://postgis.net/stuff
@@ -619,11 +625,22 @@ doxygen: doxygen.cfg ## Generate developer's documentation using Doxygen
 images: ## Generate images used in html and pdf targets
+images images-install: visual-examples
 images images-install images-uninstall images-clean:
 	$(MAKE) -C $(images_builddir) $@
+# With --with-visual-examples, render the examples from a staged build
+# when the manifest is missing; otherwise build without them.
 visual-examples:
-	@$(if $(shell test -s '$(visual_examples_manifest)' && echo ok),true,$(error Visual examples are missing. Run 'make -C regress visual-examples' first.))
+	@if ! test -s '$(visual_examples_manifest)'; then \
+		echo "Generating visual examples..."; \
+		$(MAKE) -C $(top_builddir) visual-examples || exit 1; \
+	fi
+else
+	@true
+endif
 pdf-images: visual-examples images
 	$(MAKE) -C $(images_builddir) $@ PDF_IMAGES_BUILD_DIR="$(pdf_images_builddir)"
@@ -800,7 +817,9 @@ else ifeq ($(XSLTPROC),)
 else ifeq ($(XSLBASE),)
 	@echo "Skipping $@: DocBook XSL stylesheets are not available."
 else
-	@if ! test -s "$(visual_examples_manifest)"; then \
+	@if test "$(VISUAL_EXAMPLES)" != yes; then \
+		echo "Skipping $@: configure was run without --with-visual-examples."; \
+	elif ! test -s "$(visual_examples_manifest)"; then \
 		echo "Skipping $@: visual examples are missing. Run 'make -C regress visual-examples' first."; \
 	else \
 		$(MAKE) $(html_builddir)/postgis$(DOCSUFFIX)/index.html; \
diff --git a/doc/README b/doc/README
index 04bc08b69..48972e4bd 100644
--- a/doc/README
+++ b/doc/README
@@ -49,7 +49,8 @@ How to
 Reference figures are generated from executable manual examples. Run
-``make -C regress visual-examples`` before HTML or PDF targets. The staged
+``make -C regress visual-examples`` before HTML or PDF targets (or configure
+with ``--with-visual-examples`` to have the doc targets do it). The staged
 PostGIS build supplies geometry paths and raster outputs; the renderer writes
 SVG plus a manifest under ``doc/html/images/visual-examples``. HTML embeds the
 SVG files directly, while PDF rasterizes the same files as a backend fallback.
diff --git a/doc/development/manual.md b/doc/development/manual.md
index 341e85276..6b3254ddb 100644
--- a/doc/development/manual.md
+++ b/doc/development/manual.md
@@ -62,9 +62,13 @@ renderer. Static raster files under `doc/html/images/static` are limited to
 branding and interface icons; the DocBook checker rejects other raster image
 references. Use DocBook markup for equations and tables.
-Run the example renderer before an HTML or PDF build:
+Visual examples are off by default. Configure with `--with-visual-examples`
+(requires Python 3 and a running PostgreSQL server) and `make -C doc html` or
+`make -C doc pdf` will render them automatically from a staged build when they
+are missing. They can also be rendered explicitly:
 ```sh
+./configure --with-visual-examples
 make -C doc html
 make -C doc pdf
diff --git a/doc/html/images/Makefile.in b/doc/html/images/Makefile.in
index 2cdd8e0d6..729e195d3 100644
--- a/doc/html/images/Makefile.in
+++ b/doc/html/images/Makefile.in
@@ -37,6 +37,7 @@ ALL_IMAGES = $(STATIC_IMAGES)
 PDF_IMAGES_BUILD_DIR ?= pdf-images
 PDF_IMAGES = $(ALL_IMAGES:%=$(PDF_IMAGES_BUILD_DIR)/%)
+VISUAL_EXAMPLES = @VISUAL_EXAMPLES@
 VISUAL_EXAMPLES_DIR = visual-examples
 VISUAL_EXAMPLES_MANIFEST = $(VISUAL_EXAMPLES_DIR)/manifest.json
 VISUAL_EXAMPLES_XML_MANIFEST = $(VISUAL_EXAMPLES_DIR)/manifest.xml
@@ -49,9 +50,14 @@ images: visual-examples-check $(ALL_IMAGES)
 pdf-images: $(PDF_IMAGES) visual-examples-pdf
 visual-examples-check:
 	@$(if $(shell test -s '$(VISUAL_EXAMPLES_MANIFEST)' && test -s '$(VISUAL_EXAMPLES_XML_MANIFEST)' && echo ok),true,$(error Visual examples are missing. Run 'make -C regress visual-examples' first.))
+else
+	@true
+endif
 visual-examples-pdf: visual-examples-check
 	@mkdir -p $(PDF_IMAGES_BUILD_DIR)/$(VISUAL_EXAMPLES_DIR)
 	@converter=$${POSTGIS_DOC_CONVERTER:-}; rasterizer=convert; \
 	if test -z "$$converter"; then \
@@ -88,13 +94,18 @@ visual-examples-pdf: visual-examples-check
 		mv "$$temporary" "$$target"; \
 		rm -f "$$diagnostics"; \
 	done
+else
+	@true
+endif
 images-install: visual-examples-check $(ALL_IMAGES)
 	mkdir -p $(DESTDIR)$(htmldir)/images
 	$(INSTALL_DATA) $(ALL_IMAGES) $(DESTDIR)$(htmldir)/images/
 	mkdir -p $(DESTDIR)$(htmldir)/images/$(VISUAL_EXAMPLES_DIR)
 	$(INSTALL_DATA) $(VISUAL_EXAMPLES_DIR)/*.svg $(VISUAL_EXAMPLES_MANIFEST) $(VISUAL_EXAMPLES_XML_MANIFEST) \
 		$(DESTDIR)$(htmldir)/images/$(VISUAL_EXAMPLES_DIR)/
+endif
 images-uninstall:
 	rm -f $(ALL_IMAGES:%=$(DESTDIR)$(htmldir)/images/%)
diff --git a/doc/installation.xml b/doc/installation.xml
index da7ff43e2..6fd5fac54 100644
--- a/doc/installation.xml
+++ b/doc/installation.xml
@@ -322,7 +322,8 @@ sh autogen.sh
     <listitem>
     <para>
-      Python 3 is required to run the manual example tester that generates
+      Python 3 is required, when configured with
+      <command>--with-visual-examples</command> (off by default), to run the manual example tester that generates
       the visual examples which the HTML and PDF documentation embed.
       The examples are executed against a live PostgreSQL server running the
       staged PostGIS build via <command>make -C regress visual-examples</command>;
Summary of changes:
 .woodpecker/docs.yml                         |   2 +-
 NEWS                                         |  16 ++--
 ci/debbie/postgis_release_docs.sh            |   1 +
 ci/winnie/regress_postgis.sh                 |   4 +
 ci/winnie/winnie_common.sh                   |   7 +-
 configure.ac                                 |  18 +++-
 doc/Makefile.in                              |  23 ++++-
 doc/README                                   |   3 +-
 doc/development/manual.md                    |   6 +-
 doc/html/images/Makefile.in                  |  11 +++
 doc/installation.xml                         |   3 +-
 doc/po/templates/postgis-manual.pot          | 125 ++++++++++++++++++---------
 doc/release_notes.xml                        |  13 ++-
 utils/docs/tests/test_postgis_exampletest.py |  32 ++++---
 14 files changed, 196 insertions(+), 68 deletions(-)
hooks/post-receive
