[PostGIS] #6143: [topology] False edge crossing detected
trac at osgeo.org
Mon Oct 19 00:23:07 PDT 2026
Reporter: strk | Owner: strk
Type: defect | Status: closed
Priority: blocker | Milestone: PostGIS 3.7.0
Component: topology | Version: master
Resolution: fixed | Keywords:
Comment (by Sandro Santilli <strk@…>):
In [changeset:"29bca0936d30f4e026dd4fe67e447c381c65be1a/git" 29bca09/git]:
{{{#!CommitTicketReference repository="git"
revision="29bca0936d30f4e026dd4fe67e447c381c65be1a"
Speed up edge crossing checks
Only use real numbers when needed.
Have codespell ignore "alo", used now as a variable.
References #6143
Ticket URL: <https://trac.osgeo.org/postgis/ticket/6143#comment:5>
