[PostGIS] #6147: pgis_asflatgeobuf_transfn() crashes on NULL argument
PostGIS trac at osgeo.org
Tue Oct 20 05:25:20 PDT 2026
 Reporter:  alexanderlaw  |      Owner:  pramsey
     Type:  defect        |     Status:  new
 Priority:  medium        |  Milestone:  PostGIS 3.6.5
Component:  postgis       |    Version:  master
 Keywords:                |
 The following query:
 SELECT ST_AsFlatGeobuf(NULL::spatial_ref_sys);
 or
 SELECT ST_AsFlatGeobuf(s) FROM (SELECT 1) x LEFT JOIN spatial_ref_sys s ON
 false;
 triggers a server crash:
 server closed the connection unexpectedly
         This probably means the server terminated abnormally
         before or while processing the request.
 Core was generated by `postgres: law pgis_test [local] SELECT '.
 Program terminated with signal SIGSEGV, Segmentation fault.
 #0  0x000062596ff379ea in VARATT_IS_EXTENDED (PTR=0x0) at
 ../../../../src/include/varatt.h:412
 412             return !VARATT_IS_4B_U(PTR);
 (gdb) bt
 #1  0x000062596ff3c03f in pg_detoast_datum (datum=0x0) at fmgr.c:1800
 #2  0x000076b5849f7fe0 in pgis_asflatgeobuf_transfn
 (fcinfo=0x6259a1ad3090) at
 /tmp/pg/include/postgresql/server/postgres.h:334
 #3  0x000062596f9f41b6 in ExecAggPlainTransByVal (aggstate=0x6259a1a18c38,
 pertrans=0x6259a1a1a5a0, pergroup=0x6259a1a1a7c8,
 aggcontext=0x6259a1a191c0,
     setno=0) at execExprInterp.c:5932
 #18 0x000062596fd19ff8 in exec_simple_query (query_string=0x6259a19eb020
 "SELECT ST_AsFlatGeobuf(NULL::spatial_ref_sys);") at postgres.c:1290
 This function doesn't check if argument 1 is NULL:
 PG_FUNCTION_INFO_V1(pgis_asflatgeobuf_transfn);
 Datum pgis_asflatgeobuf_transfn(PG_FUNCTION_ARGS)
         ctx->row = PG_GETARG_HEAPTUPLEHEADER(1);
 SELECT postgis_full_version()
 POSTGIS="3.7.0rc3 3.7.0rc1-119-gdcc888996" [EXTENSION] PGSQL="190"
 GEOS="3.12.1-CAPI-1.18.1" PROJ="9.4.0 NETWORK_ENABLED=OFF
 URL_ENDPOINT=https://cdn.proj.org USER_WRITABLE_DIRECTORY=...
 DATABASE_PATH=/usr/share/proj/proj.db" (compiled against PROJ 9.4.0)
 LIBXML="2.9.14" LIBJSON="0.17" LIBPROTOBUF="1.4.1" WAGYU="0.5.0
 (Internal)"
 Discovered by SQLsmith test run at Databricks.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/6147>
