[PostGIS] #6150: MVT error with GEOS 3.16
PostGIS trac at osgeo.org
Sat Oct 24 01:29:09 PDT 2026
 Reporter:  robe     |      Owner:  pramsey
     Type:  defect   |     Status:  new
 Priority:  medium   |  Milestone:  PostGIS GEOS
Component:  postgis  |    Version:  3.6.x
 Keywords:           |
 This is a little odd.  Started seeing this error on debbie despite no real
 changes since yesterday in this area. Looks like a GEOS 3.16 issue
 04:15:44  -------------- Dependencies --------------
 04:15:44   GEOS config:
 /var/lib/jenkins/workspace/geos/rel-3.15w64/bin/geos-config
 04:15:44   GEOS version:         3.16.0dev (31600)
 04:15:44   GDAL config:
 /var/lib/jenkins/workspace/gdal/rel-3.14w64/bin/gdal-config
 04:15:44   GDAL version:         3.14.0dev (31400)
 04:15:44   SFCGAL config:        /usr/bin/sfcgal-config
 04:15:44   SFCGAL version:       2.0.0
 04:15:44   CGAL version:         0
 04:15:44   PostgreSQL config:
 /var/lib/jenkins/workspace/pg/rel/pg19w64/bin/pg_config
 04:15:44   PostgreSQL version:   PostgreSQL 19rc1
 04:15:44   PostgreSQL bindir:
 04:15:44   PostGIS utilities:    ${exec_prefix}/bin
 04:15:44   PROJ version:         9.6.0 (90600)
 04:15:44   Libxml2 config:       /usr/bin/xml2-config
 04:15:44   Libxml2 version:      2.9.14
 04:15:44   JSON-C support:       yes
 04:15:44   protobuf support:     yes
 04:15:44   protobuf-c version:   1005001
 04:15:44   Perl:                 /usr/bin/perl
 I know folder says 3.15, but that's cause I forgot to flip geos master to
 write into folder geos 3.16, going to fix that now, and then keep master
 testing again 3.16, but change the 3.7.0 to use the real geos 3.15
 internal -D_GNU_SOURCE     -c -o mvt.o mvt.c -MMD -MP -MF .deps/mvt.Po
 04:16:57 In file included from ../liblwgeom/lwgeom_geos.h:31,
 04:16:57                  from lwgeom_geos.h:29,
 04:16:57                  from mvt.c:31:
 04:16:57
 /var/lib/jenkins/workspace/geos/rel-3.15w64/include/geos_c.h:6551:1:
 warning: function declaration isn’t a prototype [-Wstrict-prototypes]
 04:16:57  6551 | extern GEOSCurveToLineParams GEOS_DLL
 *GEOSCurveToLineParams_create();
 04:16:57       | ^~~~~~
 04:16:57
 /var/lib/jenkins/workspace/geos/rel-3.15w64/include/geos_c.h:6593:1:
 04:16:57  6593 | extern GEOSLineToCurveParams GEOS_DLL
 *GEOSLineToCurveParams_create();
 04:16:57       | ^~~~~~
 04:16:57 In file included from mvt.c:42:
 04:16:57 mvt.c: In function ‘add_key’:
 04:16:57 ../deps/uthash/include/uthash.h:672:20: warning: this statement
 may fall through [-Wimplicit-fallthrough=]
 04:16:57   672 |     case 11: hashv += ( (unsigned)_hj_key[10] << 24 ); /*
 FALLTHROUGH */         \
 04:16:57       |                    ^
 04:16:57 ../deps/uthash/include/uthash.h:88:46: note: in expansion of
 macro ‘HASH_JEN’
 04:16:57    88 | #define UTHASH_FUNCTION(keyptr,keylen,hashv)
 HASH_JEN(keyptr, keylen, hashv)
 04:16:57       |                                              ^~~~~~~~
 04:16:57 ../deps/uthash/include/uthash.h:150:3: note: in expansion of
 macro ‘UTHASH_FUNCTION’
 04:16:57   150 |   UTHASH_FUNCTION(keyptr, keylen, hashv);
 04:16:57       |   ^~~~~~~~~~~~~~~
 04:16:57 ../deps/uthash/include/uthash.h:420:3: note: in expansion of
 macro ‘HASH_VALUE’
 04:16:57   420 |   HASH_VALUE(keyptr, keylen_in, _ha_hashv);
 04:16:57 mvt.c:332:9: note: in expansion of macro ‘HASH_ADD_KEYPTR’
 04:16:57   332 |         HASH_ADD_KEYPTR(hh, ctx->keys_hash, name, size,
 kv);
 04:16:57 ../deps/uthash/include/uthash.h:673:5: note: here
 04:16:57   673 |     case 10: hashv += ( (unsigned)_hj_key[9] << 16 );  /*
 FALLTHROUGH */         \
 04:16:57       |     ^~~~
 macro ‘HASH_JEN’
 04:16:57       |                                              ^~~~~~~~
Ticket URL: <https://trac.osgeo.org/postgis/ticket/6150>
