[PostGIS] #6151: mingw64 on GHA showing errors
trac at osgeo.org
Sat Oct 24 01:35:29 PDT 2026
Reporter: robe | Owner: robe
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 3.7.1
Component: QA/buildbots | Version: 3.6.x
Keywords: |
I don't think this is a change in our code. Cause no code has changed
between last success and this run, so I'm guessing some change in GHA
msys/mingw64 images
gcc -I../../.. -I../../../raster -I. -I./..
-DPOSTGIS_TOP_SRC_DIR='"/d/a/postgis/postgis"' -I../../../liblwgeom
-I../../../liblwgeom -I../../../raster/rt_core
-ID:/a/_temp/msys64/mingw64/include/webp -DLIBDEFLATE_DLL
-I/mingw64/include -std=gnu11 -g -O2 -fno-math-errno -fno-signed-zeros
-Wall -O2 -c -o cu_pixtype.o cu_pixtype.c
-Wall -O2 -c -o cu_raster_basics.o cu_raster_basics.c
-Wall -O2 -c -o cu_band_basics.o cu_band_basics.c
-Wall -O2 -c -o cu_raster_wkb.o cu_raster_wkb.c
-Wall -O2 -c -o cu_raster_geometry.o cu_raster_geometry.c
-Wall -O2 -c -o cu_raster_misc.o cu_raster_misc.c
-Wall -O2 -c -o cu_band_stats.o cu_band_stats.c
-Wall -O2 -c -o cu_band_misc.o cu_band_misc.c
-Wall -O2 -c -o cu_gdal.o cu_gdal.c
-Wall -O2 -c -o cu_spatial_relationship.o cu_spatial_relationship.c
-Wall -O2 -c -o cu_mapalgebra.o cu_mapalgebra.c
-Wall -O2 -c -o cu_misc.o cu_misc.c
-Wall -O2 -c -o cu_tester.o cu_tester.c
/bin/sh ../../../libtool --mode=link gcc -I../../.. -I../../../raster -I.
-I./.. -DPOSTGIS_TOP_SRC_DIR='"/d/a/postgis/postgis"' -I../../../liblwgeom
-Wall -O2 -o cu_tester cu_pixtype.o cu_raster_basics.o cu_band_basics.o
cu_raster_wkb.o cu_raster_geometry.o cu_raster_misc.o cu_band_stats.o
cu_band_misc.o cu_gdal.o cu_spatial_relationship.o cu_mapalgebra.o
cu_misc.o cu_tester.o ../../../raster/rt_core/librtcore.a
../../../liblwgeom/.libs/liblwgeom.a -L/mingw64/lib -lgdal -lgeos_c -lproj
-lm -lcunit
libtool: link: gcc -I../../.. -I../../../raster -I. -I./..
-DPOSTGIS_TOP_SRC_DIR=\"/d/a/postgis/postgis\" -I../../../liblwgeom
-Wall -O2 -o .libs/cu_tester cu_pixtype.o cu_raster_basics.o
cu_band_basics.o cu_raster_wkb.o cu_raster_geometry.o cu_raster_misc.o
cu_band_stats.o cu_band_misc.o cu_gdal.o cu_spatial_relationship.o
cu_mapalgebra.o cu_misc.o cu_tester.o ../../../raster/rt_core/librtcore.a
-lcunit
make[3]: *** [Makefile:86: check] Error 127
make[3]: Leaving directory '/d/a/postgis/postgis/raster/test/cunit'
make[2]: *** [Makefile:19: check-unit] Error 2
make[2]: Leaving directory '/d/a/postgis/postgis/raster/test'
make[1]: *** [Makefile:83: check-unit] Error 2
make[1]: Leaving directory '/d/a/postgis/postgis/raster'
make: *** [GNUmakefile:37: check-unit] Error 1
Ticket URL: <https://trac.osgeo.org/postgis/ticket/6151>
