[PostGIS] #6153: warning: array subscript has type 'char' [-Wchar-subscripts] in liblwgeom
PostGIS trac at osgeo.org
Thu Oct 29 04:07:11 PDT 2026
 Reporter:  robe     |      Owner:  pramsey
     Type:  defect   |     Status:  new
 Priority:  medium   |  Milestone:  PostGIS 3.7.1
Component:  postgis  |    Version:  3.6.x
 Keywords:           |
 Per https://lists.osgeo.org/pipermail/postgis-
 users/2026-October/047099.html
 >> There is a large amount of ctype UB.  I don't know if this is new, but
 I think I
 >> would have noticed and said something.
 >> Briefly, ctype functions take an int, and are defined only for values
 that are
 >> valid for unsigned char or EOF.  Everything else is UB.
 >> Calling them with a variable of type char, if char is signed, leads to
 negative
 >> values.  I would expect at least some systems in CI to warn somehow,
 but
 >> maybe they don't.
 >> libtool: compile:  gcc -I../../liblwgeom/../deps/ryu/..
 -I/usr/pkg/include -
 >> I/usr/pkg/include -I/usr/pkg/include -I/usr/pkg/include/libxml2 -
 >> I/usr/pkg/include -I/usr/pkg/include -I/usr/pkg/include/json-c -DNDEBUG
 -I.
 >> -I../../liblwgeom -std=gnu11 -g -O2 -fno-math-errno -fno-signed-zeros
 -Wall -
 >> O2 -fPIC -DPIC -c ../../liblwgeom/optionlist.c  -fPIC -DPIC -o
 .libs/optionlist.o
 >> In file included from /usr/include/ctype.h:100,
 >>                  from ../../liblwgeom/optionlist.c:28:
 >> ../../liblwgeom/optionlist.c: In function
 'option_list_string_to_lower':
 >> ../../liblwgeom/optionlist.c:36:32: warning: array subscript has type
 'char' [-
 >> Wchar-subscripts]
 >>    36 |                 *key = tolower(*key);
 I researched this issue and it seems this has existed for quite sometime
 in our code possibly since 3.2.0 and there is more than this location to
 fix.
 I guess one reason only NetBSD has this warning turned on by default is
 why none of our other CIS are testing for it. Also in glibc compile it
 seems plain char is by default unsigned so it could never trigger this. I
 fussed around adding  -Wchar-subscripts -Werror=char-subscripts to
 configure on GHA cis and couldn't get them to fail. Suggestion from AI is
 to use NetBSD or Alpine or force GCC.
 So even though this is an issue, for most OS its already prevented.  Can't
 be triggered in glibc.  MingW and windows in theory can in test mode but
 production builds skip over it.
 Still worth fixing but not for 3.7.0 in case we make a mistake.  I'll
 create a fix in master and maybe put in 3.7.1 but will keep this open
 until after we have released 3.7.0
Ticket URL: <https://trac.osgeo.org/postgis/ticket/6153>
