[SCM] PostGIS branch master updated. 3.7.0rc3-5-gdbaf1d0a9
git at osgeo.org
git at osgeo.org
Fri Oct 30 11:16:50 PDT 2026
the project "PostGIS".
via dbaf1d0a9466fd3501e72fc023ca0a1051be58ca (commit)
from 80fc3d30e5ac81eabcd80a650cc3544520e862ea (commit)
revisions in full, below.
commit dbaf1d0a9466fd3501e72fc023ca0a1051be58ca
Author: Regina Obe <lr at pcorp.us>
Date: Fri Oct 30 14:15:42 2026 -0400
- Update relase-process.md to note that we need to edit matrix.json after a new minor version
- Update matrix.json, otherwise postgis.net fails on update
diff --git a/doc/development/compatibility/data/matrix.json b/doc/development/compatibility/data/matrix.json
index e6e634b2a..7df24cc56 100644
--- a/doc/development/compatibility/data/matrix.json
+++ b/doc/development/compatibility/data/matrix.json
@@ -4,8 +4,8 @@
"source_repository": "https://gitea.osgeo.org/postgis/postgis.git",
"project": {
"name": "PostGIS",
- "current_development_version": "3.7.0dev",
- "current_development_minor": "3.7"
+ "current_development_version": "3.8.0dev",
+ "current_development_minor": "3.8"
"status_definitions": {
"supported": "Supported by the PostGIS project policy for the listed release series.",
diff --git a/doc/development/release-process.md b/doc/development/release-process.md
index b702e5ae2..5cf501d03 100644
--- a/doc/development/release-process.md
+++ b/doc/development/release-process.md
@@ -1,6 +1,6 @@
title: "Release Process"
-date: 2026-06-26
+date: 2026-10-30
weight: 90
geekdocHidden: false
@@ -87,7 +87,7 @@ documentation -- that means having the required software:
1. Check access.
- Can edit tickets and milestones on https://trac.osgeo.org/postgis/
- - Can commit to upstream git https://git.osgeo.org/gitea/postgis/postgis
+ - Can commit to upstream git https://gitea.osgeo.org/postgis/postgis
- Have SSH to upload.osgeo.org and can write to /osgeo/download/postgis.
- Have SSH to postgis.net and can write to /etc/nginx/sites-enabled/postgis.net.
- Post to https://gitea.osgeo.org/postgis/postgis.net/
@@ -187,12 +187,19 @@ documentation -- that means having the required software:
postgis-${rev}.pdf \
upload.osgeo.org:/osgeo/download/postgis/docs/
+ - Adding new stable branch and flipping to master. Done after .0 release
+ - Create a new stable branch e.g. stable-3.7 for future micros and push
+ - Update master Version.config and doc\development\compatibility\data\matrix.json
+ to list the new master branch version
+ - Add to extensions\upgradeable_versions.mk the just release .0 e.g. 3.7.0
- PostGIS doc release versioned doc - https://postgis.net/documentation/
- - On postgis.net server, change /etc/nginx/sites-enabled/postgis.net (Versionless URL line )
+ - On postgis.net server, if this is a new minor release change /etc/nginx/sites-enabled/postgis.net (Versionless URL line )
- nginx -t #to confirm you didn't break the config
- service nginx reload
Verify the documentation is up to date (might need to change the nginx config)
- Post on website:
- https://git.osgeo.org/gitea/postgis/postgis.net/src/branch/website/config.toml#L155
Fix latest version pointers under `[params.postgis]` and
Summary of changes:
doc/development/compatibility/data/matrix.json | 4 ++--
doc/development/release-process.md | 13 ++++++++++---
2 files changed, 12 insertions(+), 5 deletions(-)
hooks/post-receive
