[PostGIS] #6120: XX000: SQL/MM Spatial exception - curve not simple
trac at osgeo.org
Wed Sep 2 10:10:31 PDT 2026
Reporter: Lars Aksel Opsahl | Owner: strk
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 3.6.5
Component: topology | Version: 3.6.x
Resolution: | Keywords: robustness
Comment (by strk):
I think the "Curve Not Simple" exception is due to the fact that the noded
line is computed so to have end nodes within tolerance from existing nodes
and thus result in the edge component being collapsed to a self-
intersecting curve. A MakeValid there could fix this case.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/6120#comment:11>
