[PostGIS] #6120: XX000: SQL/MM Spatial exception - curve not simple
trac at osgeo.org
Thu Sep 3 10:57:47 PDT 2026
Reporter: Lars Aksel Opsahl | Owner: strk
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 3.6.5
Component: topology | Version: 3.6.x
Resolution: | Keywords: robustness
Comment (by Sandro Santilli <strk@…>):
In [changeset:"effa73b6fe547c182f66b9f143029a20db4acaf0/git" effa73b/git]:
{{{#!CommitTicketReference repository="git"
revision="effa73b6fe547c182f66b9f143029a20db4acaf0"
Restore edge collapse handling in topology population function
The topology code used lwgeom_make_valid to handle line collapses, but
that function apparently changed semantic (see #6123 comment 2).
Includes regress test
References #6120 in 3.6 branch (3.6.5dev)
Ticket URL: <https://trac.osgeo.org/postgis/ticket/6120#comment:14>
