[PostGIS] #6120: XX000: SQL/MM Spatial exception - curve not simple
PostGIS trac at osgeo.org
Thu Sep 3 11:06:58 PDT 2026
  Reporter:  Lars Aksel Opsahl  |      Owner:  strk
      Type:  defect             |     Status:  new
  Priority:  medium             |  Milestone:  PostGIS 3.6.5
 Component:  topology           |    Version:  3.6.x
Resolution:                     |   Keywords:  robustness
Comment (by strk):
 I can't get success running tests in 3.4 and 3.3, will try again next
 week. It's also still to be found out WHEN the behavior of
 lwgeom_make_valid changed.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/6120#comment:17>
