[PostGIS] #6118: Out-of-bounds read in geometry_type_from_string() on an empty type modifier
trac at osgeo.org
Mon Sep 7 05:23:27 PDT 2026
Reporter: eivkov | Owner: pramsey
Type: defect | Status: closed
Priority: critical | Milestone: PostGIS 3.6.5
Component: postgis | Version: master
Resolution: fixed | Keywords: buffer overflow
Changes (by Darafei Praliaskouski <komzpa@…>):
* resolution: => fixed
* status: new => closed
Comment:
In [changeset:"c0793ca1e25eba653a5cc500f600daa9fd936f68/git"
c0793ca1/git]:
{{{#!CommitTicketReference repository="git"
revision="c0793ca1e25eba653a5cc500f600daa9fd936f68"
Merge pull request 'Reject empty geometry type modifiers' (!769) from
Komzpa/postgis:codex/postgis-1176-20260907 into master
Reject empty geometry type modifiers before computing the
trailing-space index in geometry_type_from_string(). This prevents an
out-of-bounds read caused by strlen(str) - 1 underflow.
Add regression coverage for empty input and preserve initialized
output values on failure.
Patch by Egor Ivkov, with SQL regression coverage and contributor
metadata updates by Darafei Praliaskouski.
Closes #6118
Closes https://github.com/postgis/postgis/pull/1176
Reviewed-on: https://gitea.osgeo.org/postgis/postgis/pulls/769
Ticket URL: <https://trac.osgeo.org/postgis/ticket/6118#comment:3>
