[SCM] PostGIS branch master updated. 3.7.0rc1-35-g17189b294
Mon Sep 7 06:23:55 PDT 2026
the project "PostGIS".
       via  17189b294f0094a60546c3f94973de6658f2db0b (commit)
       via  e150cb8d27447ab20a793bf783e4b9c64e072871 (commit)
       via  df26a094f342442572ea7132874a4a5c2a41670f (commit)
       via  e1cabf91a2c80a8dbc32a88391b10dc404415dad (commit)
      from  3ad40ec15db646e492a730c5d9fa40567b82706a (commit)
revisions in full, below.
commit 17189b294f0094a60546c3f94973de6658f2db0b
Merge: 3ad40ec15 e150cb8d2
Author: Darafei Praliaskouski <komzpa at gmail.com>
Date:   Mon Sep 7 06:23:53 2026 -0700
    Merge pull request 'Guard absent selectivity operands before reading node tags' (!771) from Komzpa/postgis:codex/postgis-1175-review-20260907 into master
    Prevent `gserialized_sel_internal` from passing an absent `other` node to
    PostgreSQL's `IsA` macro. Release `VariableStatData` and return the existing
    default selectivity before checking the node tag; the existing `Const` NULL
    path remains unchanged.
    This defensive check does not change the handling of SQL NULL values.
    Original patch by Maksim Korotkov <m.korotkov at postgrespro.ru>.
    Closes https://github.com/postgis/postgis/pull/1175
    Reviewed-on: https://gitea.osgeo.org/postgis/postgis/pulls/771
commit e150cb8d27447ab20a793bf783e4b9c64e072871
Author: Darafei Praliaskouski <me at komzpa.net>
Date:   Mon Sep 7 17:13:18 2026 +0400
    Document defensive selectivity operand check in NEWS
diff --git a/NEWS b/NEWS
index e9da6cc3c..069a05a2d 100644
--- a/NEWS
+++ b/NEWS
@@ -132,6 +132,9 @@ To take advantage of all postgis_sfcgal extension features SFCGAL 2.3+ is needed
 * Bug Fixes *
+ - GH-1175, Guard missing operands before reading node tags in
+          spatial selectivity estimation (Maksim Korotkov)
  - #6118, Reject empty geometry type modifiers without an out-of-bounds read
           (Egor Ivkov)
  - Fix WKB and TWKB parser resource exhaustion on malformed input
commit df26a094f342442572ea7132874a4a5c2a41670f
Merge: e1cabf91a 3ad40ec15
Date:   Mon Sep 7 16:43:30 2026 +0400
    Merge commit '3ad40ec15db646e492a730c5d9fa40567b82706a' into codex/postgis-1175-review-20260907
commit e1cabf91a2c80a8dbc32a88391b10dc404415dad
Author: Maksim Korotkov <m.korotkov at postgrespro.ru>
Date:   Sun Aug 23 11:52:29 2026 +0300
    Make selectivity NULL-argument guard NULL-safe
    get_restriction_variable() can return true with *other NULL when
    estimate_expression_value() folds an expression to NULL (e.g. NULLIF
    or a NULL Const). The existing guard relied on IsA(other, Const),
    which dereferences other; a NULL other would hit nodeTag(NULL) and
    crash before the check ever ran.
    Fixes: c84b3f996e2eaea3ba3afeecb783113ab16f0982
    Signed-off-by: Maksim Korotkov <m.korotkov at postgrespro.ru>
diff --git a/postgis/gserialized_estimate.c b/postgis/gserialized_estimate.c
index 15791f382..c29df1b0c 100644
--- a/postgis/gserialized_estimate.c
+++ b/postgis/gserialized_estimate.c
@@ -2052,6 +2052,13 @@ gserialized_sel_internal(PlannerInfo *root, List *args, int varRelid, int mode)
 		return DEFAULT_ND_SEL;
+	if (other == NULL)
+		ReleaseVariableStats(vardata);
+		POSTGIS_DEBUGF(2, "%s: no other argument, returning default selectivity %g", __func__, DEFAULT_ND_SEL);
+		return DEFAULT_ND_SEL;
 	if (!IsA(other, Const))
@@ -2060,7 +2067,7 @@ gserialized_sel_internal(PlannerInfo *root, List *args, int varRelid, int mode)
 	otherConst = (Const*)other;
-	if ((!otherConst) || otherConst->constisnull)
+	if (otherConst->constisnull)
 		POSTGIS_DEBUGF(2, "%s: constant argument is NULL", __func__);
Summary of changes:
 NEWS                           | 3 +++
 postgis/gserialized_estimate.c | 9 ++++++++-
 2 files changed, 11 insertions(+), 1 deletion(-)
hooks/post-receive
