[SCM] PostGIS branch master updated. 3.7.0rc1-57-g30d02784e
git at osgeo.org
git at osgeo.org
Thu Sep 10 19:39:18 PDT 2026
the project "PostGIS".
via 30d02784e09cb7d080729472ca975ecb452d42e6 (commit)
from 48ead8f0784912aae0a0bae8fd8778e629565688 (commit)
revisions in full, below.
commit 30d02784e09cb7d080729472ca975ecb452d42e6
Author: Teramoto Ikuhiro <yellow at affrc.go.jp>
Date: Fri Sep 11 02:23:57 2026 +0000
Translated PostGIS Manual using Weblate (Japanese)
Currently translated at 99.9% (6056 of 6059 strings)
Translation: postgis/PostGIS Manual
Translate-URL: https://weblate.osgeo.org/projects/postgis/postgis-manual/ja/
diff --git a/doc/po/ja/postgis-manual.po b/doc/po/ja/postgis-manual.po
index e08aabe70..3bf664acd 100644
--- a/doc/po/ja/postgis-manual.po
+++ b/doc/po/ja/postgis-manual.po
@@ -11,7 +11,7 @@ msgstr ""
"Project-Id-Version: postgis 3.5\n"
"Report-Msgid-Bugs-To: https://bugs.kde.org\n"
"POT-Creation-Date: 2026-08-04 15:37+0000\n"
-"PO-Revision-Date: 2026-09-09 08:39+0000\n"
+"PO-Revision-Date: 2026-09-11 02:39+0000\n"
"Last-Translator: Teramoto Ikuhiro <teramoto.ikuhiro576 at naro.go.jp>\n"
"Language-Team: Japanese <https://weblate.osgeo.org/projects/postgis/postgis-"
"manual/ja/>\n"
@@ -45663,6 +45663,9 @@ msgid ""
"link>, Guard missing operands before reading node tags in spatial "
"selectivity estimation (Maksim Korotkov)"
msgstr ""
+"<link xlink:href=\"https://github.com/postgis/postgis/pull/1175\">GH-1175</"
+"link>, 空間インデックスの選択性見積もりでノードタグを読む前に被演算子が無い場"
+"合の防護を追加 (Maksim Korotkov さん)"
#. Tag: para
#, no-c-format
@@ -45713,6 +45716,9 @@ msgid ""
"link>, Initialize skipped union-find cluster ids deterministically (Darafei "
"Praliaskouski)"
msgstr ""
+"<link xlink:href=\"https://trac.osgeo.org/postgis/ticket/5975\">#5975</link>"
+", Union-Find でクラスター ID を必ず初期化するよう変更 (Darafei Praliaskouski "
+"さん)"
#. Tag: para
#, no-c-format
@@ -45767,6 +45773,9 @@ msgid ""
"link>, ST_ClusterRelateWin validates NULL relate matrices before detoasting "
"them (Darafei Praliaskouski)"
msgstr ""
+"<link xlink:href=\"https://github.com/postgis/postgis/pull/886\">GH-886</"
+"link>, ST_ClusterRelateWin の交差行列文字列が NULL の場合に TOAST から戻す前"
+"に評価するよう変更 (Darafei Praliaskouski さん)"
#. Tag: para
#, no-c-format
@@ -45775,6 +45784,9 @@ msgid ""
"link>, ST_Relate pattern inversion avoids out-of-bounds access on short "
"DE-9IM patterns (Darafei Praliaskouski)"
msgstr ""
+"<link xlink:href=\"https://github.com/postgis/postgis/pull/889\">GH-889</"
+"link>, ST_Relate のDE9IM 文字列を内部で転置させる際に短い文字列では範囲外"
+"エラーになるのを回避 (Darafei Praliaskouski さん)"
#. Tag: para
#, no-c-format
@@ -45830,6 +45842,10 @@ msgid ""
"cleanup, GDAL credential redaction, and Python GDAL compatibility (Darafei "
"Praliaskouski)"
msgstr ""
+"<link xlink:href=\"https://github.com/postgis/postgis/pull/894\">GH-894</"
+"link>, [raster] Float16 のインポート、NODATA 混合時の変換処理、バンド入替時の"
+"古いバンドの消去、GDAL の資格情報消去、Python GDAL の互換性に関する修正 "
+"(Darafei Praliaskouski さん)"
#. Tag: title
#, no-c-format
@@ -48549,6 +48565,10 @@ msgid ""
"in geometry_columns, as will a typmod one. In this example we define a "
"column using typmod and another using constraints."
msgstr ""
+"制約による定義にはまだ対応していますが、制約による定義がなされた"
+"ジオメトリーカラムはビュー内で直接使うと geometry_columns に正しく登録されま"
+"せん。型修飾子による定義は登録されます。この例では型修飾子による定義と制約に"
+"よる定義を 1件ずつ行っています。"
#. Tag: para
#, no-c-format
@@ -48575,6 +48595,8 @@ msgid ""
"The typmod based geom view column registers correctly, but the constraint "
"based one does not."
msgstr ""
+"ビュー内で型修飾子による定義がされている geom カラムは正しく登録され、制約に"
+"よる定義カラムは正しくは登録されていません。"
#. Tag: para
#, no-c-format
@@ -48582,6 +48604,9 @@ msgid ""
"This may change in future versions of PostGIS, but for now to force the "
"constraint-based view column to register correctly, you need to do this:"
msgstr ""
+"これは PostGIS の将来のバージョンで変更される可能性がありますが、現在は制約に"
+"よる定義がなされたビューカラムを強制的に正しく登録するには次のことを行う必要"
+"があります:"
#. Tag: title
#, no-c-format
Summary of changes:
doc/po/ja/postgis-manual.po | 27 ++++++++++++++++++++++++++-
1 file changed, 26 insertions(+), 1 deletion(-)
hooks/post-receive
