[PostGIS] #6129: Missing area with topology.ST_GetFaceGeometry('arstat_2026_overlay_02_348',101383), but alle edges seems to be prensent
trac at osgeo.org
Sat Sep 12 02:07:32 PDT 2026
Reporter: Lars Aksel Opsahl | Owner: strk
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 3.6.5
Component: topology | Version: 3.6.x
Resolution: | Keywords:
Comment (by strk):
Ok now I see and confirm the problem. From my dump the "offending" face is
face 9.
The function generating the face geometry (`ST_GetFaceGeometry`) is unable
to build the correct geometry, completely dropping the exterior ring.
[[Image(missingArea9.png)]]
I also confirm the `ST_Collect` vs. `ST_Union` difference, with the
`ST_Union` version evidently including the outer ring:
strk at strk=# select ST_Area(ST_BuildArea(ST_Union(e.geom))) from t6129.edge
e where e.left_face = 9 or e.right_face = 9;
st_area
0.0002930648390859782
(1 row)
Time: 8.704 ms
strk at strk=# select ST_Area(ST_BuildArea(ST_Collect(e.geom))) from
t6129.edge e where e.left_face = 9 or e.right_face = 9;
st_area
1.2519093540856632e-05
(1 row)
Time: 15.293 ms
It sounds like a robustness issue. I'll take a closer look at
ST_GetFaceGeometry.
My relevant versions:
POSTGIS="3.7.0dev 3.7.0rc1-61-gf8777b8ce"
GEOS="3.14.1-CAPI-1.20.5"
Ticket URL: <https://trac.osgeo.org/postgis/ticket/6129#comment:9>
