[PostGIS] #6129: Missing area with topology.ST_GetFaceGeometry('arstat_2026_overlay_02_348',101383), but alle edges seems to be prensent
PostGIS trac at osgeo.org
Sat Sep 12 02:33:35 PDT 2026
  Reporter:  Lars Aksel Opsahl  |      Owner:  strk
      Type:  defect             |     Status:  new
  Priority:  medium             |  Milestone:  PostGIS 3.6.5
 Component:  topology           |    Version:  3.6.x
Resolution:                     |   Keywords:
Comment (by strk):
 The bug seems to be fully inside ST_BuildArea, either it's a but there OR
 the edges are not properly noded according to GEOS:
 strk at strk=# select st_area(st_buildarea(st_collect(geom))) from
 t6129_outer_ring_edges;
  st_area
 (1 row)
 strk at strk=# select st_area(st_buildarea(st_union(geom))) from
         st_area
  0.00030558393262683487
 (1 row)
 The t6129_outer_ring_edges table is created by t6129_outer_ring_edges.sql
 just attached
Ticket URL: <https://trac.osgeo.org/postgis/ticket/6129#comment:12>
