[PostGIS] #6129: Missing area with topology.ST_GetFaceGeometry('arstat_2026_overlay_02_348',101383), but alle edges seems to be prensent
trac at osgeo.org
Sat Sep 12 09:41:39 PDT 2026
Reporter: Lars Aksel Opsahl | Owner: strk
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 3.6.5
Component: topology | Version: 3.6.x
Resolution: | Keywords:
Comment (by strk):
This is the relation between any pair of edges:
=# select count(*), rel from ( select ST_Relate(e1.geom, e2.geom) rel from
t6129_outer_ring_edges e1, t6129_outer_ring_edges e2 where e2.edge_id >
e1.edge_id ) foo group by 2;
count | rel
367 | FF1F00102
66794 | FF1FF0102
(2 rows)
No pair has any interior-interior (1st matrix position) or interior-
boundary (2nd and 4th position) intersection.
No single edge is non-simple, but the output of
ST_LineMerge(ST_Collect(geom)) is non-simple:
=# select count(*) filter ( WHERE not ST_IsSimple(geom) ) nonsimple_count,
ST_IsSimple(ST_LineMerge(ST_Collect(geom))) from t6129_outer_ring_edges;
nonsimple_count | st_issimple
0 | f
(1 row)
I'm calling this a bug in ST_LineMerge!
Ticket URL: <https://trac.osgeo.org/postgis/ticket/6129#comment:18>
