[PostGIS] #6129: Missing area with topology.ST_GetFaceGeometry('arstat_2026_overlay_02_348',101383), but alle edges seems to be prensent
trac at osgeo.org
Sat Sep 12 10:21:27 PDT 2026
Reporter: Lars Aksel Opsahl | Owner: strk
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 3.6.5
Component: topology | Version: 3.6.x
Resolution: | Keywords:
Comment (by strk):
One workaround to move on with data cleaning, in this specific case would
be to add a single-segment edge from node 309 to node 310, so to form a
new tiny face on the right of edge 304 (and left of the new edge), and
then drop edge 304. Identifier numbers are those from the t6129.pgtopo
export.
But we can't add that single-segment new edge either because that edge 304
has those 2 segments being almost coincidental and this introduces
robustness problems, so we first need to add a vertex to 304, changing
it's geom as in the below picture:
[[Image(edge304-changed-geom.png)]]
Then adding the new edge works:
# select ST_AddEdgeModFace('t6129', 309, 310, ( select
ST_MakeLine(n1.geom, n2.geom) from t6129.node n1, t6129.node n2 where
n1.node_id = 309 and n2.node_id = 310 ));
st_addedgemodface
385
(1 row)
[[Image(new-edge-385.png)]]
Then we remove the offending edge:
=# select st_remedgemodface('t6129', 304);
st_remedgemodface
10
(1 row)
[[Image(UpdatedProblematicAreaDetail.png)]]
And finally we can get the proper area:
# select ST_Area(ST_GetFaceGeometry('t6129', 10));
st_area
0.0002930648390859782
(1 row)
Note that this method makes the face of intereset change identifier (from
9 to 10 in this case) because ST_RemEdgeModFace keeps the identifier of
the face on the right side, which in our case will be the new tiny face.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/6129#comment:20>
