[PostGIS] #6132: ST_LineMerge turns a set of fully-noded simple lines into a non-simple line
trac at osgeo.org
Sat Sep 12 11:25:57 PDT 2026
Reporter: strk | Owner: pramsey
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 3.7.0
Component: postgis | Version: 3.6.x
Resolution: | Keywords:
Comment (by strk):
I've tested the attached testcase linemerge.sql against GEOS-3.10.8dev-
CAPI-1.16.7 and current GEOS main: the problem persists.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/6132#comment:1>
