[SCM] PostGIS branch master updated. 3.7.0rc1-71-ged8527bca
git at osgeo.org
git at osgeo.org
Mon Sep 28 08:46:39 PDT 2026
the project "PostGIS".
via ed8527bca7653bb86644b05235f8b72380743db4 (commit)
via 33d2b44e857c9e73c30005e82365dca5347e22af (commit)
from dfdaa24812e35bc88a64aa57c5a686408e38f4e9 (commit)
revisions in full, below.
commit ed8527bca7653bb86644b05235f8b72380743db4
Merge: dfdaa2481 33d2b44e8
Author: Regina Obe <lr at pcorp.us>
Date: Mon Sep 28 08:46:16 2026 -0700
Merge pull request '- Don't try to build visual images for sfcgal if sfcfal building is disabled' (!802) from robe/postgis:doc-conditional-build-sfcgal into master
Closes https://trac.osgeo.org/postgis/ticket/6134
Reviewed-on: https://gitea.osgeo.org/postgis/postgis/pulls/802
commit 33d2b44e857c9e73c30005e82365dca5347e22af
Date: Mon Sep 28 08:57:20 2026 -0400
- Don't try to build visual images for sfcgal if sfcgal building is disabled
diff --git a/doc/README b/doc/README
index dc0e308c1..04bc08b69 100644
--- a/doc/README
+++ b/doc/README
@@ -61,6 +61,11 @@ manual at https://gitea.osgeo.org/postgis/postgis/src/branch/master/doc/developm
for layout roles, labels, textual-output policy, native geometry/EWKT output
handling, and the visual review procedure.
+A build configured ``--without-sfcgal`` still documents the SFCGAL reference
+chapter, but the renderer skips the SFCGAL examples that would have to execute,
+and no figures are emitted for them. The examples that render from their
+recorded documented output are unaffected and keep their figures.
To run garden tests against functions, see the Garden Checks section in
https://gitea.osgeo.org/postgis/postgis/src/branch/master/doc/development/testing/.
diff --git a/doc/development/manual.md b/doc/development/manual.md
index 5937159d4..341e85276 100644
--- a/doc/development/manual.md
+++ b/doc/development/manual.md
@@ -78,6 +78,32 @@ Raster-returning SQL examples are also executed at build time; their exact
pixels are embedded in the generated SVG container rather than checked in as a
manual screenshot.
+### Optional backends and figures
+An example is rendered only when the backend it needs is present. Two mechanisms
+cooperate:
+* A `requires-<backend>-<version>` role on the `programlisting` or `screen`
+ gates a single example, and `requires-cgal-<version>` gates on the CGAL
+ version. A version the server does not report is treated as unavailable, so
+ the example is skipped rather than failed.
+* A whole chapter can be gated instead. `CHAPTER_CAPABILITY_REQUIREMENTS` in
+ [`utils/docs/postgis_exampletest.py`](../../utils/docs/postgis_exampletest.py)
+ maps a chapter `xml:id` to the backend every runnable example in it needs.
+ The SFCGAL reference chapter is gated this way because most of its examples
+ carry no per-example role. Documented-output examples are exempt, because they
+ are drawn from their recorded `<screen>` output and never execute.
+A figure is emitted only when the manifest holds an entry for that block, so a
+skipped example degrades to its recorded text output instead of a broken image.
+Do not add a figure for an example that a backend gate will skip.
+A build configured `--without-sfcgal` passes `--disable-sfcgal`, which tells the
+renderer to treat SFCGAL and CGAL as unavailable without probing the server.
+The SFCGAL reference chapter is still documented and its SFCGAL cheatsheet,
+comment script, and garden script are still built, but the examples in that
+chapter that would have to execute are omitted along with their figures.
Garden checks combine documentation examples with behavior validation. Keep the
command and review guidance in [Testing and debugging](testing/_index.md#garden-checks)
and link back here when manual examples need attention.
diff --git a/doc/xsl/postgis-dblatex-block-labels.xsl b/doc/xsl/postgis-dblatex-block-labels.xsl
index 29670a408..b306959a2 100644
--- a/doc/xsl/postgis-dblatex-block-labels.xsl
+++ b/doc/xsl/postgis-dblatex-block-labels.xsl
@@ -61,18 +61,24 @@
</xsl:variable>
<xsl:variable name="manifest.visual"
select="document($postgis.visual.manifest)/visual-examples/visual[@refentry = $refentry.id and @screen = string($screen.ordinal)]"/>
+ <!-- A figure is only emitted when the manifest actually holds an entry for
+ this block. Examples skipped at build time (unavailable backend, or
+ the visual-skip role) never reach the manifest, and referencing their
+ SVG would break the PDF include. The same test guards
+ visual.preferred so the text output is not dropped in favour of a
+ figure that was never built. -->
<xsl:variable name="visual.id">
<xsl:choose>
- <xsl:when test="contains($role.tokens, ' visual-primary ') and (@xml:id or @id)">
+ <xsl:when test="$manifest.visual and contains($role.tokens, ' visual-primary ') and (@xml:id or @id)">
<xsl:value-of select="(@xml:id | @id)[1]"/>
</xsl:when>
<xsl:otherwise><xsl:value-of select="$manifest.visual/@id"/></xsl:otherwise>
</xsl:choose>
</xsl:variable>
<xsl:variable name="visual.preferred"
- select="not(contains($role.tokens, ' text-primary '))
- and ($manifest.visual/@preferred = 'true'
- or (not($manifest.visual) and contains($role.tokens, ' visual-primary ')))"/>
+ select="string($visual.id) != ''
+ and not(contains($role.tokens, ' text-primary '))
+ and $manifest.visual/@preferred = 'true'"/>
HTML can keep a large WKT output collapsed next to its interactive figure.
In the non-interactive PDF the preferred figure carries the same geometry,
diff --git a/doc/xsl/postgis-html-block-labels.xsl b/doc/xsl/postgis-html-block-labels.xsl
index a92a9cb85..8cc37f4f5 100644
--- a/doc/xsl/postgis-html-block-labels.xsl
+++ b/doc/xsl/postgis-html-block-labels.xsl
@@ -160,7 +160,7 @@
select="document($postgis.visual.manifest)/visual-examples/visual[@refentry = $next.refentry.id and @screen = string($next.screen.ordinal)]"/>
<xsl:choose>
- <xsl:when test="$next.screen and contains($next.screen.role.tokens, ' visual-primary ') and $next.screen/@xml:id">
+ <xsl:when test="$next.screen and $next.manifest.visual and contains($next.screen.role.tokens, ' visual-primary ') and $next.screen/@xml:id">
<xsl:value-of select="$next.screen/@xml:id"/>
</xsl:when>
<xsl:when test="$next.screen"><xsl:value-of select="$next.manifest.visual/@id"/></xsl:when>
@@ -281,18 +281,23 @@
<xsl:with-param name="kind" select="'show-readable-ewkt'"/>
</xsl:call-template>
</xsl:variable>
+ this block. Examples skipped at build time (unavailable backend, or the
+ visual-skip role) never reach the manifest, and referencing their SVG
+ would emit a broken image. The same test guards visual.preferred so the
+ text output is not hidden in favour of a figure that was never built. -->
<xsl:choose>
- <xsl:when test="contains($role.tokens, ' visual-primary ') and @xml:id">
+ <xsl:when test="$manifest.visual and contains($role.tokens, ' visual-primary ') and @xml:id">
<xsl:value-of select="@xml:id"/>
</xsl:when>
</xsl:choose>
</xsl:variable>
<div role="group" data-postgis-block="output">
<xsl:attribute name="class">
diff --git a/regress/Makefile.in b/regress/Makefile.in
index 13870797b..3ebd86103 100644
--- a/regress/Makefile.in
+++ b/regress/Makefile.in
@@ -29,9 +29,19 @@ POSTGIS_MICRO_VERSION=@POSTGIS_MICRO_VERSION@
GARDENDB=postgis_garden
EXAMPLETESTDB=postgis_exampletest
-EXAMPLETEST_RUN_FLAGS = --keep-going
EXAMPLETEST_VISUAL_JOBS ?= 2
+# A build without the SFCGAL backend cannot run the SFCGAL chapter examples or
+# produce their figures. Tell the tester so it skips them instead of probing
+# for functions that were never installed. Each target spells out its own
+# EXAMPLETEST_RUN_FLAGS below, so this has to be repeated there too.
+ifeq ($(HAVE_SFCGAL),yes)
+EXAMPLETEST_SFCGAL_FLAGS =
+else
+EXAMPLETEST_SFCGAL_FLAGS = --disable-sfcgal
+endif
+EXAMPLETEST_RUN_FLAGS = --keep-going $(EXAMPLETEST_SFCGAL_FLAGS)
# Where we put our regression installation
# See https://trac.osgeo.org/postgis/ticket/5066
ifeq ($(MINGWBUILD),1)
@@ -152,7 +162,7 @@ exampletest: staged-install exampletest-run
visual-examples: staged-install visual-examples-run
-visual-examples-run: EXAMPLETEST_RUN_FLAGS = --keep-going --visual-only --jobs $(EXAMPLETEST_VISUAL_JOBS)
+visual-examples-run: EXAMPLETEST_RUN_FLAGS = --keep-going --visual-only --jobs $(EXAMPLETEST_VISUAL_JOBS) $(EXAMPLETEST_SFCGAL_FLAGS)
visual-examples-run: EXAMPLETEST_CHECK_ENVIRONMENT = no
visual-examples-run: exampletest-run
diff --git a/utils/docs/postgis_exampletest.py b/utils/docs/postgis_exampletest.py
index af3611c47..ca7a50031 100755
--- a/utils/docs/postgis_exampletest.py
+++ b/utils/docs/postgis_exampletest.py
@@ -73,6 +73,17 @@ FUNCTION_CAPABILITY_REQUIREMENTS = (
("cgal", (6, 0, 0), re.compile(r"\bCG_PolygonRepair\s*\(", re.I)),
+# Chapters that document an optional backend wholesale. Every runnable example
+# in them needs that backend, and most carry no per-example role, so the chapter
+# itself supplies the requirement. The minimum is the oldest SFCGAL PostGIS can
+# be configured against at all (configure.ac rejects anything below 1.3.1), so
+# this only ever tests for presence: an absent backend reports an empty version
+# and fails the comparison. Documented-output examples are exempt at example
+# level, because they are rendered from their recorded output and never execute.
+CHAPTER_CAPABILITY_REQUIREMENTS = {
+ "reference_sfcgal": ("sfcgal", (1, 0, 0)),
+ "reference_sfcgal_legacy": ("sfcgal", (1, 0, 0)),
ENVIRONMENT_CHECKS = (
"label": "PROJ grid au_icsm_GDA94_GDA2020_conformal_and_distortion.tif",
@@ -195,9 +206,14 @@ CATALOG_QUERY_RE = re.compile(r"\bpg_available_extensions\b", re.I)
class ExampleTester:
- def __init__(self, xml_file):
+ # Class-level default so helpers keep working on instances built with
+ # __new__ (the parser-only callers in the unit tests).
+ disabled_capabilities = frozenset()
+ def __init__(self, xml_file, disabled_capabilities=()):
self.index = parse_xml(xml_file)
self.doc = self.index.tree
+ self.disabled_capabilities = frozenset(disabled_capabilities)
def node_text(self, node):
return "".join(node.itertext()).replace("\r\n", "\n").replace("\r", "\n")
@@ -239,6 +255,24 @@ class ExampleTester:
return requirements
+ def chapter_capability_requirements(self, node):
+ requirements = []
+ for ancestor in self.index.ancestors(node):
+ if ancestor.tag != f"{{{DOCBOOK_NS}}}chapter":
+ continue
+ requirement = CHAPTER_CAPABILITY_REQUIREMENTS.get(
+ ancestor.get(f"{{{XML_NS}}}id")
+ if requirement is None:
+ continue
+ name, minimum = requirement
+ requirements.append({
+ "name": name,
+ "minimum": minimum,
+ "role": f"requires-{name}-" + ".".join(str(part) for part in minimum),
+ return requirements
def merge_capability_requirements(self, requirements):
merged = {}
for requirement in requirements:
@@ -251,6 +285,9 @@ class ExampleTester:
def runtime_capabilities(self, database, names):
capabilities = {}
for name in sorted(names):
+ if name in self.disabled_capabilities:
+ capabilities[name] = ()
+ continue
query = CAPABILITY_VERSION_QUERIES[name]
try:
value = self.run_psql_scalar(database, query)
@@ -1380,6 +1417,7 @@ class ExampleTester:
"requirements": self.merge_capability_requirements(
self.capability_requirements(node)
+ self.inferred_capability_requirements(query)
+ + ([] if documented_only else self.chapter_capability_requirements(node))
"documented_only": documented_only,
"volatile": self.query_is_version_example(query) or self.query_is_catalog_example(query),
@@ -1794,6 +1832,8 @@ class ExampleTester:
example for example in all_examples
if not self.requirements_satisfied(example.get("requirements", []), capabilities)
+ # Documented-output figures are drawn from their recorded screen and never
+ # touch a backend, so they are deliberately not capability filtered.
documented_visuals = [
if example.get("documented_only") and example["visual_id"]
@@ -4639,6 +4679,11 @@ def parse_args():
parser.add_argument("--render-dir", help="write selected build-time SVG assets after a successful --run")
parser.add_argument("--visual-only", action="store_true", help="run only selected visual examples")
parser.add_argument("--jobs", type=int, default=1, help="parallel workers for --visual-only (default: 1)")
+ parser.add_argument(
+ "--disable-sfcgal",
+ action="store_true",
+ help="treat the SFCGAL backend as unavailable without probing the server",
parser.add_argument("xml_file")
return parser.parse_args()
@@ -4647,7 +4692,8 @@ def main():
args = parse_args()
try:
- tester = ExampleTester(args.xml_file)
+ disabled_capabilities = {"sfcgal", "cgal"} if args.disable_sfcgal else ()
+ tester = ExampleTester(args.xml_file, disabled_capabilities=disabled_capabilities)
if args.report:
tester.print_report()
diff --git a/utils/docs/tests/test_postgis_exampletest.py b/utils/docs/tests/test_postgis_exampletest.py
index 3d120d150..abf114c58 100644
--- a/utils/docs/tests/test_postgis_exampletest.py
+++ b/utils/docs/tests/test_postgis_exampletest.py
@@ -491,6 +491,96 @@ SELECT 'POINT(1 2)', $$LINESTRING(0 0,1 1)$$,
"role": "auto-requires-sfcgal-2.0.0",
}], requirements)
+ def _example_in_chapter(self, chapter_id, roles=""):
+ xml = f"""<book xmlns="http://docbook.org/ns/docbook">
+ <chapter xml:id="{chapter_id}">
+ <refentry xml:id="CG_Extrude"><refsection>
+ <programlisting{roles}>SELECT ST_AsText(
+ CG_Extrude('POLYGON((0 0,1 0,1 1,0 0))'::geometry, 0, 0, 10)
+ );</programlisting>
+ <screen role="visual-primary text-primary">POLYGON Z ((0 0 0,1 0 0,1 1 0,0 0 0))</screen>
+ </refsection></refentry>
+ </chapter>
+</book>"""
+ with tempfile.TemporaryDirectory() as directory:
+ path = Path(directory) / "chapter.xml"
+ path.write_text(xml, encoding="utf-8")
+ examples = ExampleTester(path).examples()
+ self.assertEqual(1, len(examples))
+ return examples[0]
+ def test_sfcgal_chapter_example_requires_sfcgal_backend(self):
+ example = self._example_in_chapter("reference_sfcgal")
+ self.assertEqual(
+ [{"name": "sfcgal", "minimum": (1, 0, 0), "role": "requires-sfcgal-1.0.0"}],
+ example["requirements"],
+ self.assertFalse(example["documented_only"])
+ self.assertEqual("visual-cg-extrude-01", example["visual_id"])
+ def test_sfcgal_legacy_chapter_example_requires_sfcgal_backend(self):
+ example = self._example_in_chapter("reference_sfcgal_legacy")
+ self.assertEqual(
+ def test_example_outside_sfcgal_chapter_is_not_gated(self):
+ example = self._example_in_chapter("reference_processing")
+ self.assertEqual([], example["requirements"])
+ def test_documented_output_in_sfcgal_chapter_keeps_its_figure(self):
+ # Documented-output examples are drawn from their recorded screen and
+ # never execute, so they must not be gated on the backend.
+ example = self._example_in_chapter("reference_sfcgal", ' role="documented-output"')
+ self.assertTrue(example["documented_only"])
+ def test_disabled_sfcgal_capability_skips_chapter_examples(self):
+ tester = ExampleTester.__new__(ExampleTester)
+ requirement = [
+ {"name": "sfcgal", "minimum": (1, 0, 0), "role": "requires-sfcgal-1.0.0"}
+ # A backend that is absent, disabled at configure time, or whose version
+ # function is missing all report an empty version and must not satisfy
+ # the chapter requirement.
+ self.assertFalse(tester.requirements_satisfied(requirement, {"sfcgal": ()}))
+ self.assertFalse(tester.requirements_satisfied(requirement, {}))
+ self.assertTrue(tester.requirements_satisfied(requirement, {"sfcgal": (1, 5, 0)}))
+ self.assertTrue(tester.requirements_satisfied(requirement, {"sfcgal": (2, 3, 0)}))
+ def test_disable_sfcgal_short_circuits_runtime_capabilities(self):
+ calls = []
+ def record(database, query):
+ calls.append(query)
+ return "2.3.0"
+ tester.run_psql_scalar = record
+ tester.disabled_capabilities = frozenset({"sfcgal", "cgal"})
+ self.assertEqual(
+ {"cgal": (), "sfcgal": ()},
+ tester.runtime_capabilities("db", {"sfcgal", "cgal"}),
+ self.assertEqual([], calls)
+ calls.clear()
+ tester.disabled_capabilities = frozenset()
+ self.assertEqual(
+ {"sfcgal": (2, 3, 0)},
+ tester.runtime_capabilities("db", {"sfcgal"}),
+ self.assertEqual(["SELECT postgis_sfcgal_version()"], calls)
def test_legacy_2d_wkt_output_compares_against_2d_projection(self):
query = tester.geometry_comparison_query(
Summary of changes:
doc/README | 5 ++
doc/development/manual.md | 26 ++++++++
doc/xsl/postgis-dblatex-block-labels.xsl | 14 +++--
doc/xsl/postgis-html-block-labels.xsl | 15 +++--
regress/Makefile.in | 14 ++++-
utils/docs/postgis_exampletest.py | 50 +++++++++++++++-
utils/docs/tests/test_postgis_exampletest.py | 90 ++++++++++++++++++++++++++++
7 files changed, 201 insertions(+), 13 deletions(-)
hooks/post-receive
