[PostGIS] #6136: ST_MakeValid merges polygons in a MultiPolygon.
trac at osgeo.org
Tue Sep 29 01:43:07 PDT 2026
Reporter: Lars Aksel Opsahl | Owner: pramsey
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 3.6.5
Component: postgis | Version: 3.6.x
Keywords: |
In the MULTIPOLYGON below, eight polygons contain internal intersections,
making the geometry invalid.
Running ST_MakeValid() removes most of the internal boundaries and reduces
the result to only two polygons in attached file.
Is this the expected behavior?
If so, it might be useful to have a function such as
ST_MakeValidPreserveTopology() that preserves the original polygon
boundaries and structure as much as possible to produce a valid geometry.
This was tested with:
POSTGIS="3.7.0dev 3.6.0rc2-473-g260127869"
PGSQL="16.0"
GEOS="3.14.1-CAPI-1.20.5"
PROJ="9.8.1"
and on other servers with similar results.
ST_Buffer(geom, 0) behaves almost the same way, except that it returns
three polygons instead of two in attached file.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/6136>
