[postgis] Re: How to use pgsql2shp
jeff lounsbury jeffloun at refractions.net
Thu Dec 6 10:04:46 PST 2001
Hmmm, that error gets printed whenever there is more than a single geometry
type in the result of the query so maybe you join is creating some rows that
have Null geometry types and the dumped doesn't handle that very nicely I
notice looking at it. Can you send me any more info you have, maybe a dump of
your table possibly and I can try to look at it, but I'm pretty busy these
days with other projests so I can't promise much timeliness. Feel free to
poke at the code yourself, i assuming you probably just have to check for a
unique geomtry OR (a unique one plus some NULL's ) bracketed is not happening
in current code. Or maybe I'm completly wrong and something is happening due
to the view instead of a basic table.
-Jeff
lr1234567 wrote:
> Jeff,
> That part I understand about the limitation of shp, but the geometry
> table I was joining with only has one type of geometry
> (multipolygons) - and that is the geometry field I am selecting in my
> view.  The other table I am joining with has no geometries.
> My view query looks something like this
> SELECT ap.*, l.the_geom
> FROM ap INNER JOIN landparcels l ON ap.parcelid = l.parcelid
> landparcels is the one with the geometry field of type multipolygon
> and ap has no geometries - just a simple postgres table.
> I assumed that if I defined my new table remsactive setting the
> geometry type the same as my landparcels, I would only have one type
> of geometry.
> Note that if I try to dump out landparcels using pgsql2shp it works
> fine.  Or is the fact that I am inserting from a view posing a
> problem.
> --- In postgis at y..., jeff lounsbury <jeffloun at r...> wrote:
> > This is simply a limitation of the .shp format. The format only
> allows a file
> > to consists of homogeneous shape types.
> > eg  all Points , all MultiPolygons etc...
> > What you can do if you really need the shapes in .shp format is
> keep the
> > different types in separate PostGIS tables and then dump each of
> the tables.
> > The other possibility is converting all the shapes to the most
> complex type.
> > eg. Just call points multipoints so you can have a single
> multipoint .shp
> > file. If the types are very different like points and mutipolygons,
> this will
> > probably not work though.
> > -Jeff
> > lr1234567 wrote:
> > > Is there a particular structure that pgsql2shp is expecting
> > > When I try to use it on a table I created it generates the dbf
> fine,
> > > but can't generate the shp file
> > > It states as an error, can not have multiple geometry types in a
> > > shape file.
> > > It works fine on tables I generated using the shp2pgsql loader.
> > > The way I created and populated the table I'm trying to dump out
> is
> > > as follows
> > > create table remsactive ( PARCELID varchar(10), ADDRESS varchar,
> > > NEIGHBORHO varchar, USE varchar, TYPE varchar, STATUS varchar,
> > > LOTAREA int);
> > > select AddGeometryColumn
> > > ('dts','remsactive','the_geom','102686','MULTIPOLYGON',2);
> > > INSERT INTO remsactive(gid, parcelid, address, neighborho,use,
> type,
> > > status, lotarea, the_geom)
> > > SELECT gid, parcelid, address,neighborhood, cuse, propertytype,
> > > status, sqfeet,the_geom
> > > FROM vwavailableparcels;
> > > _______
> > > the vwavailableparcels is a view I set up that joins a table of
> > > multipolygon geometries I loaded from a shape file with a non-
> > > geometry table.
> > > To unsubscribe from this group, send an email to:
> > > postgis-unsubscribe at y...
> > > Your use of Yahoo! Groups is subject to
> http://docs.yahoo.com/info/terms/
> postgis-unsubscribe at yahoogroups.com
> Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
