[postgis] Why is there the limitation of PGLIB to get the cursor?
TONY J.Y.
tjiang at mrf.com
Fri Dec 7 10:21:02 PST 2001
Paul,
I have never used the precompiled library libpq.
I installed the postgressql 7.1.3. with the source-code
postgressql7.1.3source-tar.gz on my linux box.
After that, I expanded the postgressql7.1.3source-tar.gz file in my
client win2k box.
Using the "nmake -f win32.mak" get the win2k box Lib and DLL.
What is your meaning for your this sentence?
"The problem is with your *particular* copy/version of libpq on the
win2000 box."
What I need to do to get the correct copy/version of libpq in the win2k
box?
Looking forward to your suggestion.
.. /tony
----- Original Message -----
To: <postgis at yahoogroups.com>
Sent: Friday, December 07, 2001 10:15 AM
Subject: Re: [postgis] Why is there the limitation of PGLIB to get the
cursor?
> There is no limit in libpq in general, because psql *uses* libpq, and
> you demonstrated on the linux box that it worked for you. The problem is
> with your *particular* copy/version of libpq on the win2000 box. Time to
> check out the source code you are working with. If you are using a
> precompiled libpq, maybe now is the time to compile your own...
> "TONY J.Y." wrote:
> > Dave,
> > I went to the linux server where the database was located. Ran
the
> > psql session to declare
> > the big cursor and fetch all in the cursor. there was no error
> > there. I could declare the cursor,
> > and fetched all rows from the cursor. So PostgreSQL
server-side
> > is OK. The asbinary function
> > is OK too.
> > I ran my program at client side (Win2K Pro with libpq). There
> > came the error message when the
> > geom data is bigger:
> > "char *PQerrorMessage(const PGconn* conn);"
> > Error = pqReadData() -- read() failed: errno=0
> > So there is some limit in the pqReadData() -- read() of the C
> > library libpq, isn't there?
> > ../Tony
> > From: "Dave Blasby" <dblasby at refractions.net>
> > Sent: Thursday, December 06, 2001 10:42 AM
> > cursor?
> > > Tony,
> > > I looked at your code and it looks like it should work. I suggest
you
> > > open a "psql" session to the DB and type in all the commands that your
> > > program sends to the database. When you execute the "FETCH ALL"
> > > command, you should get an error message.
> > > You could also call the "char *PQerrorMessage(const PGconn* conn);"
> > > function after the "FETCH ALL" command fails.
> > > Hopefully the error message will guide you as to the problem.
> > > The binary cursor is only limited by your machine's memory.
> > > dave
> > > To unsubscribe from this group, send an email to:
> > > postgis-unsubscribe at yahoogroups.com
> > > Your use of Yahoo! Groups is subject to
http://docs.yahoo.com/info/terms/
> Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
