[postgis] Re: JTS 0.9 has been released
Hisaji ONO
ono96 at fa2.so-net.ne.jp
Tue Dec 18 06:03:10 PST 2001
Thank you very much for your great work, Mr. Davis.
I've tried to create some programs by using JTS's jars.
If possible, could you show any simple sample java programs using JTS?
Regards.
> I'm happy to announce that a pre-release version of the Java Topology
Suite
> is now available for download at
> http://www.vividsolutions.com/jts/jtshome.htm
> This version is functionally complete (apart from isSimple and isValid,
> which will be release shortly).
> The spatial predicates are robust under both Fixed and Floating precision
> models. The spatial overlay and buffer functions are unfortunately not
> fully robust. The overlay functions should perform similarly to most
other
> spatial APIs, however. The buffer function is robust and precise for many
> inputs, but does have known failure cases.
> We invite comments, and especially suggestions on robust, precise
> algorithms.
To unsubscribe from this group, send an email to:
postgis-unsubscribe at yahoogroups.com
Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
