[postgis] distance(geometry,geometry) function
Timothy H. Keitt
tklistaddr at keittlab.bio.sunysb.edu
Tue Jul 24 11:58:21 PDT 2001
Dave Blasby wrote:
>Yes, these are euclidean distances. The calculations in geodetic
>coordinates are complex.
>We have a function that, given a spheroid and 2 geodetic points, will
>calculate the distance between them. In order to do distance() in
>generality, I need to be able to;
>1. Given a spheroid and the points A, B, and C. A-B define a line in
>geodetic space (a great circle). Find the minimum distance (also a
>great circle) between the line AB and C.
>2. Given a spheroid and the points A, B and U, V. A-B and U-V define
>lines in geodetic space. Tell me if they intersect or the minimum
>distance between then.
>3. Given a spherioid, the point A, and the polygon P tell me if point A
>is inside the polygon P.
>Then I'd need to dust off my spherical geometry and make sure my
>euclidean assumptions will hold on an ellipsoid.
>Does anyone know how to calculate these things?
Not in general, no. This is all made more complex by the fact that
postgis points and polygons are not seperate SQL types, but are instead
mixed together within a single column of type "geometry", so you have to
make your function accept all types of geometry objects. I'm curious
why you chose this path instead of making each geometric type a
different SQL type as with the built-in postgresql geometry types? Come
to think of it, I'm not sure what postgis provides that the built-in
types don't (except maybe much faster queries?).
I agree with Frank that a quick wrapper around PROJ.4 would be a good
short-term solution for handling datum projections.
Tim
Timothy H. Keitt
Department of Ecology and Evolution
State University of New York at Stony Brook
Stony Brook, New York 11794 USA
Phone: 631-632-1101, FAX: 631-632-7626
http://life.bio.sunysb.edu/ee/keitt/
------------------------ Yahoo! Groups Sponsor ---------------------~-->
Small business owners...
Tell us what you think! http://promo2.yahoo.com/sbin/Yahoo!_BusinessNewsletter/survey.cgi
http://us.click.yahoo.com/vO1FAB/txzCAA/ySSFAA/PhFolB/TM
To unsubscribe from this group, send an email to:
postgis-unsubscribe at yahoogroups.com
Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
