[postgis] Fixed - odd insert problem
Dave Blasby dblasby at refractions.net
Tue Jun 19 17:09:07 PDT 2001
Frank Warmerdam wrote:
> The error seems to be in the assumptions about 4 vs. 8 byte alignment.  It
> seems that under linux stuff only needs to be four byte aligned.
This is exactly what was wrong.  Sparc aligns doubles on 8 bytes and
i386 aligns on 4 bytes.  This causes problems when the GEOMETRY
structure was originally created on a 4-byte boundary, then later
re-allocated on a 8-byte boundary (or vis-versa).  This would never
happen on a sparc.
The solution is easy, replace everything that looks like:
>             if ((int32) pts != (((int32)pts>>3)<<3) )
>                 pts = (POINT3D *) ((char *) pts + 4);
with
	     pts = (POINT3D *) MAXALIGN(pts);
I was going to do this in a later release anyways since its more
readable.
{ On a sparc, the MAXALIGN macro will align to 8 byte boundaries, and on
i386 to 4 byte boundaries}
Release 0.2 will have this fix in it.
dave
To unsubscribe from this group, send an email to:
postgis-unsubscribe at yahoogroups.com
Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
