[postgis] Re: Postgis Compilation
Paul Ramsey
pramsey at refractions.net
Tue Nov 6 12:52:33 PST 2001
Yet... the makefile is a bit (a big) of an ugly hack right now. There
are two assumptions going on: (a) that you have untarred the postgis
tarball in ./contrib of the postgis source distro and (b) that your
source distro has already been compiled and the compiled files left
there. I am cheating -- rather than discovering the actual location of
your libpq, I am trying to link to a copy in the source tree. So go into
your postgresql source tree and type 'make', so there are compiled
copies of the libraries etc sitting there.
Mark Wilson and Dawn Brodie wrote:
> Paul,
> I downloaded the CVS snapshot as of yesterday.
> I still have a problem, but the error message is a little more
> meaningful. However, I'm still not sure what I need to change. I suspect
> it is some environment variable that I need to set.
> All the files in my ISP's virtual server directory tree are prefixed with
> /usr/home/wwholida/usr/local (instead of /usr/local) This wasn't a
> problem with Postgres installation as I used the PREFIX option. I'm not
> sure why I'm getting the error below. Any pointers??
> Thanks again,
> Mark
> Here is the output when I now execute gmake in the contrib/postgis-src
> directory:
> gmake -C loader
> gmake[1]: Entering directory
> `/usr/home/wwholida/usr/local/postgresql-7.1.3/cont
> rib/postgis-cvs/loader'
> gcc -pipe -O2 -Wall -Wmissing-prototypes -Wmissing-declarations shpopen.o
> dbfope
> n.o getopt.o shp2pgsql.o -L../../../src/interfaces/libpq -lpq
> -R/usr/home/wwhol
> ida/usr/local/lib/contrib -lz -lcrypt -lcompat -lm -lutil -lreadline -o
> shp2pgs
> ql
> /usr/libexec/elf/ld: cannot find -lpq
> gmake[1]: *** [shp2pgsql] Error 1
> gmake[1]: Leaving directory
> `/usr/home/wwholida/usr/local/postgresql-7.1.3/contr
> gmake: *** [loaderdumper] Error 2
> >Mark,
> >What version of the code are you using? Try using the CVS snap and see
> >if things improve...
> >P.
> >> Hi Paul,
> >> I'm not sure if you can help me.
> >> I am trying to install PostGIS v0.6.1 on to of Postgresql 7.1.3 on a
> >> FreeBSD 4.2 unix box.
> >> I believe I've followed all the necessary instructions (as far as I can
> >> tell). Below is my output from the PostGIS gmake command.
> >> Any clues on what I'm doing wrong, or what is missing?
> >> Thanks in advance,
> >> Mark Wilson
__
| Paul Ramsey
| Refractions Research
| Email: pramsey at refractions.net
| Phone: (250) 885-0632
\_
To unsubscribe from this group, send an email to:
postgis-unsubscribe at yahoogroups.com
Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
