[postgis] JDBC and WKB; shp2postgresql
dougvanauken
dougvanauken at worldnet.att.net
Sat Nov 24 14:55:22 PST 2001
I four questions regarding WKB and JDBC:
First question:
Does anyone have some examples on how to insert and retreive geometry
using WKB and JDBC:
Second question:
According to the OpenGIS SQL specicification an insert using WKB
would use the following format:
INSERT INTO Countries (Name, Location) VALUES ('Kenya', PolygonFromWKB
(:wnb, :srid)).
Using this format, how do you insert an WKB object using JDBC?
As an example, if I have this:
Polygon polygon = new Polygon(...);
PreparedStatement pstmt = cnn.prepareStatement("INSERT INTO Countries
(Name, Location) VALUES ('Kenya', ?)
pstmt.setOject(1, polygon)
How would I implement PolgyonFromWKB(:wkb, :srid)?
Second question:
Is the following the correct way to retreive an object using JDBC and
WKB?
ResultSet rst = cnn.executeQuery("SELECT Name, AsBinary(Location)
FROM Countries WHERE Name like 'k%');
while(r.next()){
String name = r.getString(1)
PGgeometry geometry = (PGgeometry)r.getObject(2);
Third question:
If I insert an object as text, can I retreive it as binary, and vice-
versa -- If I insert it as binary, can I retreive it as text?
------------------------ Yahoo! Groups Sponsor ---------------------~-->
Universal Inkjet Refill Kit $29.95
Refill any ink cartridge for less!
Includes black and color ink.
http://us.click.yahoo.com/ltH6zA/MkNDAA/ySSFAA/PhFolB/TM
To unsubscribe from this group, send an email to:
postgis-unsubscribe at yahoogroups.com
Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
