[postgis] Querying mapserver with data from PostGIS table
Ewa Patrowicz
ewap at arges.pl
Fri Oct 5 03:48:55 PDT 2001
I have a situation:
- shape "xxx" with attributies :
geometry, ident, description
I constructed map layer
LAYER
NAME "ss"
DATA "xxx"
HEADER "xxx_hdr.htm"
TEMPLATE "xxx_tmpl.htm"
FOOTER "xxx_ftr.htm"
CLASS
END
END
When querying this layer I obtained good results. For example
"1-st description"
"2-nd description"
"71-th description"
Trouble is when I try using postgis table
- table "xxxx" with columns :
Table contained the same data as the shape above.
LAYER
NAME "sss"
CONNECTIONTYPE postgis
CONNECTION ...
DATA "geometry FROM xxxx"
CLASS
END
END
I used the same template query files xxx_*.htm as the names of columns and attributies were the same.
When querying this layer I obtained a list of labels instead of values.
Using the same circumstances :
[DESCRIPTION]
[DESCRIPTION]
[DESCRIPTION]
What could I do for obtaining the correct result in this situation?
Ewa.
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20011005/94c810f7/attachment.html>
