[postgis] problem when install on redhat 86
Paul Ramsey pramsey at refractions.net
Sat Oct 13 23:01:24 PDT 2001
More information please :) Hardware is not at issue, the precise steps
you went through in compiling and installing are, as are the exact error
conditions you are seeing.
P.
lzw63china at yahoo.com wrote:
> I can't install the postgis on my machine.
> my hardware is x86 with 128M memory
>    software : redhat7.1 with postgresql-7.1.2(default install)
> when i finished install the postgis version > 0.1,   I can't finish
>      psql -d mydatabase < postgis.sql
> the error message is abort.
> When I install the postgis-0.1, I can do it well, I can create table
> with geometry field, but I can't insert the geometry value to the
> table, the error message is file load fail of libpostgis.so.0.1.
> To unsubscribe from this group, send an email to:
> postgis-unsubscribe at yahoogroups.com
> Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
