[postgis] Itemquery in postgis
Ross.Searle
Ross.Searle at dnr.qld.gov.au
Mon Sep 3 14:52:32 PDT 2001
Paul,
I have not let the query run to completion as the browser keeps timing out
so there is no way to seee if anything is going to be returned. I have both
a spatial index which works sensationally and an index on the item value
which appears not to be working.
Regards
Ross
-----Original Message-----
From: Paul Ramsey [mailto:pramsey at refractions.net]
Sent: Tuesday, 4 September 2001 4:13 AM
To: postgis at yahoogroups.com
Subject: Re: [postgis] Itemquery in postgis
Hm, does it take literally "forever" or does it just take a very very
long time? An index on the attribute value you are searching is a good
idea too... itemquery is something we haven't tested, so I bet there is
something amiss in the code.
Ross.Searle at dnr.qld.gov.au wrote:
> Hi,
> I'm trying to retrieve records from a large table in postgres through an
> itemquery in mapserver. It appears as if mapserver doesn't utilise the
index
> for the table as the same query run directly in postgres takes
approximately
> 1 sec whereas the same query through mapserver takes forever. Has anyone
got
> any clues as to what might be going on
> Thanks
> Ross
> The information in this e-mail together with any attachments is
> intended only for the person or entity to which it is addressed
> and may contain confidential and/or privileged material.
> Any form of review, disclosure, modification, distribution
> and/or publication of this e-mail message is prohibited.
> If you have received this message in error, you are asked to
> inform the sender as quickly as possible and delete this message
> and any copies of this message from your computer and/or your
> computer system network.
> To unsubscribe from this group, send an email to:
> postgis-unsubscribe at yahoogroups.com
> Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
------------------------ Yahoo! Groups Sponsor ---------------------~-->
Secure your servers with 128-bit SSL encryption! Grab your copy of VeriSign's FREE Guide: "Securing Your Web Site for Business." Get it Now!
http://us.click.yahoo.com/n7RbFC/zhwCAA/yigFAA/PhFolB/TM
