[postgis] SRID for LAT/LONG
Frank Warmerdam
warmerdam at pobox.com
Fri Sep 28 14:30:39 PDT 2001
Roderick A. Anderson wrote:
> A few questions.
> 1. Is there a generally accepted or defned AUTH_SRID for LAT/LONGs?
Rod,
If you use EPSG as your authority, there are a lengthy list of Geographic
Coordinate systems. Essentially these are lat/long with different datums.
A few common ones follow. I can provide the WKT if you want, or you can
look it up in the ct_epsg.txt file yourself.
4326: WGS84
4267: NAD27
4269: NAD83
> 2. Does or will PostGIS support LAT/LONG and Elevations as a coordinate
> system?
Do you mean, will PostGIS allow you to use a compound coordinate system
descripting the horizontal (lat/long) and vertical (elevation) axeses?
There is a way to do this in WKT, but it isn't widely used yet. Since
PostGIS doesn't do anything special with the 3rd dimension I would encourage
you to just use the 2d coordinate system descriptions, and maintain the
interpretation of the elevation yourself.
If you mean, will PostGIS let you use points with x=long, y=lat and
z=elevation, yes, it certainly will.
> 3. Does or will GiST indexes support LAT/LONGs when determining the
> bounding box for the GIS object?
I have used lat/long layers and had no problem with indexing.
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
------------------------ Yahoo! Groups Sponsor ---------------------~-->
Get your FREE VeriSign guide to security solutions for your web site: encrypting transactions, securing intranets, and more!
http://us.click.yahoo.com/UnN2wB/m5_CAA/yigFAA/PhFolB/TM
To unsubscribe from this group, send an email to:
postgis-unsubscribe at yahoogroups.com
Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
