> The shp2pgsql (Date 24. July 2002) from CVS still craches with shapes > contains columns with NULL values. When I fill up the NULL value column > with any value shp2pgsql will work fine. Could you provide a small sample file and the shp2pgsql call that you're using? Steffen
