AW: [postgis-users] shp2pgsql problems with NULL value columns
Düster Horst
Horst.Duester at bd.so.ch
Wed Aug 7 09:54:20 PDT 2002
Here the sample shape with NULL values in the attributes ANFINDEX and
ENDINDEX. When I import this shape with
shp2pgsql -c -D adrstr_numpos adrstr DBname ¦ psql -d DBname
shp2pgsql crashes with message:
ERROR: copy: line 1, pg_atoi: error in "NULL": can't parse "NULL"
lost synchronization with server, resetting connection
After filling the two attributes with 0 shp2pgsql works.
Thank you for your help.
Horst
-----Ursprüngliche Nachricht-----
Von: Steffen Macke [mailto:sdteffen at web.de]
Gesendet am: Mittwoch, 7. August 2002 16:33
An: postgis-users at postgis.refractions.net
Betreff: Re: [postgis-users] shp2pgsql problems with NULL value columns
> The shp2pgsql (Date 24. July 2002) from CVS still craches with shapes
> contains columns with NULL values. When I fill up the NULL value column
> with any value shp2pgsql will work fine.
Could you provide a small sample file and the shp2pgsql call
that you're using?
Steffen
postgis-users mailing list
http://postgis.refractions.net/mailman/listinfo/postgis-users
Type: application/octet-stream
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20020807/a3792e05/attachment.obj>
