[postgis-users] postgis connection problem
porfidia porfidia at anpa.it
Fri Aug 9 11:07:01 PDT 2002
Chris Hodgson wrote:
> Could you please be a little more specific? What is this URL or path that
> you are using? Can you give us a little more info about what you are trying
> to do, overall?
> Chris
> ----- Original Message -----
> From: "porfidia" <porfidia at anpa.it>
> To: <postgis-users at postgis.refractions.net>
> Sent: Friday, August 09, 2002 9:53 AM
> Subject: [postgis-users] postgis connection problem
> > I solved that problem
> > and shp2img doesn't give errors and i can visulize the output with the
> > browser, but when  i put the path of that mapfile in the src img for
> > apache  i can't see anything
> postgis-users mailing list
sorry for previous message
I checked  mapserver and postgis connection with sh2img command and and i
found the errors i did, then when  i finally got a working postgis.map file i
tried to put its path in the apache /htdocs/index.html file such as
<img
src="http://10.158.1.126/cgi-bin/mapserv?map=/var/www/postgis.map&mode=map">
and I can't see anything.
If I put in the same file the old  mapfile i used before without any
connection to postgis, it works
thanks  in advance
I know that i'm wrong somewhere but i don't understand where
benedetto
