> Ok, > I will add entry in the spatial_ref_sys table for each new > Postgis-enabled database. You dont need anything in the spatial_ref_sys table UNLESS you're using transform() to re-project your data. According to the OGC spec, you do need to have entries in the geometry_columns table. dave
